A new calibration, this one done with an i1 Display Pro as opposed to either DTP94b or i1 Pro (yes, Xrite's naming convention is awful, the i1 Display Pro has nothing to do with the i1 Pro, one is a colorimeter spectrally calibrated and one is a spectrophotometer), some early signs hint that the i1 Display Pro is the best probe, better than even the $$ i1 Pro. Anyway here is the one with the new probe (and I must say it is a little disturbing that every single different probe used gives a different balance, although the two DTP94b gave the closest results to each other, anyway, some evidence points to the i1 Display Pro as possibly being the most true though).
Mode: Movie
Back Light: 5 for room with no lights, raise it as you add more lights (calibration was done at BL 6 in dark room)
Contrast: 91
Brightness: 44
Sharpness: 0 (VERY damaging to turn this on for a digital signal)
Color: 49
Tint: 50/50
Eco: Off
Black Tone: Off
Dynamic Contrast: Off
Shadow Detail: +2
Gamma: +1
Color Space: Custom [X (R,G,B) : R (43,8,0); G (32,54,0); B (0,9,74);
Y (52,51,0); C (2,54,57); M (44,8,58)]
White Balance: (25,23,27; 26,32,16)
10 pt WB:
1 8,8,8
2 1,1,2
3 -2,-3,-4
4 -3,-4,-5
5 -1,-3,-3
6 0,-1,-5
7 0,1,-3
8 1,1,0
9 1,1,2
10 0,-1,0
Flesh Tone: 0
Edge Enhancement: 0 (very damaging for digital signals in particular)
Picture: Warm2
DNR : Off
MPEG DNR: Off
HDMI Black Level: as needed (usually Normal for PCs and Low for other stuff but sometimes game boxes can need Normal depending upon how they are set)
