EVEN BETTER THAN BEFORE
These provide about 3300:1 contrast ratio on my set and give Power Function gamma 2.22 and 105 cd/m^2 (HCFR claims 4876:1 CR, gamma 2.25).
If you are willing to not care quite as much about 90-100% gamma curve (which isn't perfect anyway) you could sacrifce a trace of realism for closer to a 4000:1 CR by boosting contrast to 98. That would also very slightly toss off WB and the rest of the gamma curve as well but probably not by too horrifically much.
I have a feeling I could still tweak the very top end a touch to get a bit more CR.
This profile is less twisted.
It doesn't bend magenta saturation as much and it also lets red at 100% get much closer to the full sRGB saturation spec and has even more refined gamma.
I found that even though Calman defaults to testing the gamut at 75% for the way the color engine works in the C650 it is better to test it at 100%.
Mode: Movie
Backlight: 6
Contrast: 90
Brightness: 44
Sharpness: 0
Color: 51
Tint: 50/50
Eco: Off
Black Tone: Off
Dynamic Contrast: Off
Shadow Detail: 0 (I swear I don't notice any change, but perhaps I should measure and see what happens)
Gamma: 0
triads are all (R,G,B) below
Color Space: Custom
R 37,1,0
G 28,50,1
B 4,5,59
C 18,52,61
M 39,3,55
Y 50,50,1
White Balance:
Offsets: 28,23,23
Gains: 26,24,26
10pt WB and Gamma (this control is used to straighten out the kinks on the gamma curve every bit as much as it is to fine tune white balance) control:
1 8,10,8
2 0,2,2
3 -2,1,-2
4 -1,1,-4
5 -1,0,-5
6 -1,1,-6
7 0,3,-4
8 -4,0,-4
9 -1,2,-2
10 -1,3,1
Flesh Tone: 0
Edge Enhancement: Off (unless maybe watching under composite,component)
Warm2
Screen Fit
DNR: Off
MPEG DNR: Off
HDMI Black Level: Normal if you send it black=0-255=white material (most PC usage, but sometimes other things if they are set this way) and Low if you send it balck=16-235=white material (most set top boxes and stand alone players)
AMP: Off (although you certainly fiddle with it)
This was calibrated to a Power Function gamma curve of 2.22.
Yeah.... these look really good.
