AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › Any opinions of the new 320gb AV HDD from WD with hd tv
post #1 of 3
it's supposed to be optimized for video storage and playback blah blah blah. i'm in the market for another drive and i've been using my 640gb wd just fine for a little over a year on my wd hd tv player and it seems to look good except for a few panning and artifact issues... which i would most likely attribute to compression and/or the video card. would an "optimized for video playback" hdd change much you think? anyone tried this or read any real reviews on it?
post #2 of 3
I've used several regular 1TB, 1.5TB and 2TB USB drives with my WDTV and WDTV Live and the only one that had any issues was a Seagate Freeagent 1.5TB USB drive which caused occasional brief pauses in the video. I know WD has sold some exteral drives specifically for video storage intended for use with a DVR. This is an application where the drive may be running 24/7 and it uses a more expensive 'server' class drive. However, with the WDTV you will normally only be running the drive when actually using the WDTV so a regular consumer PC class of drive should be sufficient. Since I use my WDTV (Live) for HD video, anything under 1TB is too small to be very useful.
post #3 of 3
Thank you Ron Jones you are indeed a special member.
