Originally Posted by
bgronostaj
I'm surprised they aren't made for large rooms. I think the clarity and power I get from them are great in my basement. The tv viewing area is about 15x35. I was going to get a new center, possibly some new bookshelves and leave the existing 4 paradigm speakers for surround. What do you suggest for a room that size?
The lower the sensitivity of a speaker the more power is required to maintain a certain sound level (SPL). At 87db and only able to handle up to 80 watts they max out quite early. You may be experiencing distortion and not just high volume levels.
Look at it this way:
At 87db one Cinema 70 puts out 87db at 1 meter with one watt - to increase the spl to 90db takes 2 watts (double the power for every 3db increase) - still at 1 meter (this is a constant)
etc etc - but what you need to remember is for every meter you move back from the speaker you lose ~3db. If you are sitting 4 meters back - ~17' you lose SPL very fast - a small speaker can get lost in a large room - and thats what you may be experiencing.
From MichaelJHuman's excellent AVR FAQ - a word on SPL
Speaker pressure level; Speaker efficiency 85 dB; Measured one meter from speaker
Input Power (in watts) -> Speaker Pressure Level (SPL)
1 -> 85
2 -> 88
4 -> 91
8 -> 94
16 -> 97
32 -> 100
64 -> 103
Speaker pressure level; Speaker efficiency 90 dB; Measured one meter from speaker
1 -> 90
2 -> 93
4 -> 96
8 -> 99
16 -> 102
32 -> 105
64 -> 108
100 -> 110 (approx)
120 -> 111 (approx)
You should notice that it takes very little power to hit 90 dB. We will hear 91 dB from four watts of input into an 85 dB speaker and 90 dB with with one watt of input to a 90 dB speaker. Obviously sensitive speakers make a difference.
You should try adjusting the center channel sound level - higher than the front L-R by 3-5db to start and see what that does for you before rushing out to buy a new center channel. If you determine you need a different one find a Paradigm speaker to replace it that will timbre match with your L/R speakers.
