This is a questionnaire for the owners of the Viewsonic Pro8100 only. It is meant to try and understand how prevalent the horizontal banding problem is on this projector and to try and understand what might make some projector's horizontal banding (HB) worse than others. Please take the time to fill it out. Please let me know if there are questions that I should add/remove. Thank you.
1. Have you ever noticed HB when watching your projector's image? (yes or no. If no, skip to question 2)
1a) What sort of scenes do you notice HB most often in?
1b) Is there anything that seems to make the HB less noticeable?
1c) Is there anything that seems to make the HB more noticeable?
1d) How many hours were on your unit when you started noticing HB?
1e) Have you notified Viewsonic of your HB?
1f) If you've had a HB effected projector replaced by VS, did the replacement also have HB (if yes, how many have you had)?
2. What is your build date?
3. What is your seating distance from the screen?
4. What is your screen size, gain?
5. Are your settings optimized for the blackest blacks or for a brighter image?
6. Have you tried using a 2nd party power cord?
7. Have you modified your projector at all? eg. new filter, shielding etc.
8. Are there any large appliances connected to the same circuit as your projector?
9. What sort of cables (and their length) are connected to your projector?
10. Is your projector ceiling or shelf mounted?
11. How is your projector plugged in? (eg directly to outlet, surge protector)
12. Have you tried a 2 prong adapter and was it effective?
13. Have you tried an Isolation Transformer and was it effective?
