AVS › AVS Forum › AVS Forum Information › Forum Operations Center › A/V Newbie needs help
post #1 of 2
I'm a computer type guy that's just been put in an Audio/Visual job.
I really new to the field and need help in finding resources for basic understanding of equipment, troubleshooting, and purchasing.
Are there any web sites for A/V 101 type training? For instance I don't know the difference between RGB and RGBHV. Why add 2 more signals?
Also, can anyone recommend any books to purchase that explains the raw basics of A/V? Also, is there a print magazine I should be buying?
All suggestions appreciated.
thanks, Alex
post #2 of 2
Depending on what you're doing, I think you'll find online content more current than print media as things change quickly. I would recommend searching AVS for keywords as they come up. There's a wealth of info here, but as you may have discovered by now, it's all specifically categorized and not as generalized as you might hope for.
Happy Hunting & welcome to AVS.
  Back to Forum: Forum Operations Center
