Originally Posted by downtick
my issue is still happening!! So I turned my router off for a while, and the sound did not drop once. I put it back on, and within a minute or so rear speakers were cutting out. I will try different channels as well for the router. Which channel did you try that worked for you? I know I tried this once before, but only to one other channel. At least now I KNOW what the problem is!
I fear I spoke too soon last night - and this problem was the lack of connection to the router at all.
When I typed that I had a solution, I was able to connect to my router and keep a stable connection on Channel 5 or 6 - I'd need to check, I chose one in the middle at random.
This allowed me to get through and make contact with the various media providers - Netflix, Amazon, Hulu, etc. and to then get through the menus to the place where I could select a movie to play.
At that point the E770W is still freezing - I either get a response "this movie is not available for download at this time" or it gets as far as "checking link speed" and then just spins and spins until it times out. Then I sometimes get a message "connection cannot be established" but when I go to the network settings I actually am connected to my router just fine.
Sigh.
