I have been looking into upgrading from my cheapo 150Lumen projector to something a little brighter and sharper. I have been looking at the Viewsonic PJD6531w which has 3000 ANSI Lumens. I used the calculator at projectorcentral to see how bright it would be. The calculator says that I would be getting roughly 142 Foot Lamberts from my 1.2 gain screen at 7'7" away to get a 90" picture! I would think that that'd be extremely bright. Would I be correct in this thinking?
The projectors that I run at Rave are mainly calibrated to be shooting about 10.2-14 Foot Lamberts for normal theaters and 18-24 for 3D theaters. So from what I've seen, it seems like anything over 50+ Foot Lamberts could end up being uncomfortably bright.
I do have a light controlled room, but it is a very small 10' by 12' room. If you need any more info please just say.
If I did get this projector and it was too bright even with it calibrated and everything is there anything that I can do to turn down the brightness if it is a problem. I remember reading about ND2-6 filters?
Thanks in advance
Thanks in advance
