I've been out of home theatre/audio for a few years while living in places with unsuitable environments for a quality system. My system that I bought in High School is in storage, and I want to salvage some parts and upgrade others. I am going to list the equipment I have currently, as well as the floor plan. I will really appreciate any help. I am on a tight budget, which is why I want to save/reuse as much equipment as possible.
I am looking at the best options for a quality system for everyday use. I mostly play Xbox Live and watch sports. Movies only 2 or 3 times a week.
Floor Plan (Apt #1) 1795 sq. ft. 10' ceilings. Polished hardwood floors (I think I will add a large rug).
There is a fireplace, and the TV (probably 50" plasma) will be above it. The fireplace is between the windows on the outside wall (far left). There is just no other way it will work. I am going to have the TV mounted as low as possible.
Current equipment:
Receiver - Marantz SR6200
Fronts- Paradigm Phantom
HSU HB-1
Rears - Paradigm ADP-170
Center - Paradigm CC-150
Sources:
Xbox 360 + HD DVD + NetFlix Streaming
FIOS TV
Need to buy:
Sub-Woofer
Blu-ray player
Current equipment:
HSU HB-1
Sources:
FIOS TV
Need to buy:
Sub-Woofer
Blu-ray player
