AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The "Official" Pioneer VSX-1020-K Owner's Thread
The "Official" Pioneer VSX-1020-K Owner's Thread - Page 53
post #1561 of 4530
This happens only when I am watching cable (Dish). I am reading the manual for A.Delay... in the meantime, I will replicate your set up and give it a try...
post #1562 of 4530
Originally Posted by JChin View Post
Dish > HDMI > Receiver
BD Player > HDMI > Receiver
Receiver out > HDMI > TV in
Tv "Digital Audio Out" > optical cable > Receiver optical port
I just ordered the optical cable. Question: you dont need optical cable between the SAT and the receiver?
post #1563 of 4530
You will find that some channels you watch will have some delay and some don't. A couple things to try is to change channel and back or rewind the show/movie a second or two and then play.
post #1564 of 4530
You do not need optical cable from SAT to receiver like iontyre mention.
Unless your SAT box can't output surround sound DD 5.1 via HDMI (which most do now).
post #1565 of 4530
JChin,
Page 23 of the manual shows a Optical cable between TV and the receiver and page 27 shows Optical connection between Cablebox and receiver. Which one to use?
1020-K Manual
post #1566 of 4530
Guys does the VSX1020 support audio return channel or standby pass-through ?
post #1567 of 4530
JChin,
1020-K Manual
Ok, page 23 is used if you want sound from your Tv (like using the Internet@Tv feature) not from your SAT cable box.
Page 27 is option for audio connection only for your SAT cable box if you're not using HDMI. For example using component cables for video and then you would need an extra cable for audio.
post #1568 of 4530
Im thinking about picking this one up. My old Pioneer VSX-609's center channel died recently. Had that receiver for 11 years. Not bad I think, and I think it is finally time to upgrade to something that does all the new BR Sound formats and can handle/upscale all my video sources.
post #1569 of 4530
iontyre,
As I am really new at this, I blindly followed the manual. You are right, if I remove the RCA cable, I still get the sound, but there is still a lag. Do you think speaker cable length makes a difference? My cables are longer than they should be... I am also planning to purchase TOSLink cable and connect the SAT to the receiver. How is your system connected? I am using AudioQuest HDMI cables - SAT to receiver, BD to Receiver and Receiver to TV.
Do you get the lag (occasionally)?
I still don't get what you are trying to do. All my components use hdmi to the receiver, with one hdmi out to the TV. That is it, nothing from the TV back to the receiver. If you are getting lag, I believe the receiver has a setting adjustment for that too.
post #1570 of 4530
First post here. Just bought the vsx-1020-k, and I plan on buying a 3d tv...but this audio return channel i dont understand. Will i still get my dolby true-hd and such with no ARC? Im severely confused and i have been poring over the forums and this ARC doesnt seem like its a deal breaker. As long as i can still get my sound formats and my 3d picture, it seems like the receiver for me. I plan on hooking up my 3d tv, xbox 360, wii, and my blu ray player and cable box. (i just ordered it on amazon, and will hook it up when i move into my new hoe on oct 15)
post #1571 of 4530
yes... you will be fine...
arc is for passing audio from the tv back to the avr... this is really only useful if you are a ota user or you have some type of media player on your display that you use...
post #1572 of 4530
^^thank you for the help. as a newbie im so scared of being eaten alive by threadcrappers
post #1573 of 4530
Does the VSX-1020 support standby pass-through ? or only the 1120 does ?
post #1574 of 4530
The 1020 sort of does pass through. Only for devices that support control over hdmi.
post #1575 of 4530
I have:
1. PS3
2. Samsung UN46B8500
3. Energy Take classic 5.1
4. Cable box
Would the 1020 support pass through in this set up ?
post #1576 of 4530
I can't get this unit to playback my iPhone 4. It has ios 4.01. It connects and the drops when I try to playback any music. Works with my nano and touch.
post #1577 of 4530
Originally Posted by karun View Post
Here it is again for clarity:
setup 1 (no VSX1020)
PS3 --- (30 ft cable) ----- Projector (1080 p - no issues)
setup 2 (with VSX 1020)
PS3 -- (3 feet cable) -- VSX1020 --- (30 ft cable) -- Projector
(1080p - sparkles in picture)
(1080i - no sparkles in picture)
If I cannot fix this issue, I will have to start finding out about the Amazon return policy. I like the 1020 though but I need 30 feet cable between avr and projector.
Hi Karun
I have what seems to be the same problem with the 1020 using a Samsung BD player. The white dots (noise). Cable length makes no difference. I notice that the problem is only on the BD input. Any other HDMI input, and the noise dissapears. The 1020 won't pass 3D. Did you find a solution to the problem you were having?
Al
post #1578 of 4530
Originally Posted by ismatta View Post
Hi Karun
Al
I have a similar problem with my projector when I upgraded from my Yamaha to the Pioneer. I used a monoprice switcher to a/b my tv/projector. The tv worked fine, but the projector either wouldn't work or would get the sparklies. The projector is a Mitsubishi.
If I directly connect the projector to the receiver with the same cable, no problem.
I tried a monoprice hdmi 4x2 matrix switch instead, and it would work only if the projector was on a specific port (I can't remember which).
I can only conclude that the Pioneer puts out slightly less signal than the Yamaha did and that a passive switch reduces it more, but the matrix less.
I can't comment on 3d.
post #1579 of 4530
Originally Posted by yowzator View Post
Thanks for the tip. Setting my fronts to small seems to have enabled the subwoofer. I'll need to experiment with things now to find the best crossover frequency and such.
I've read and manual and this thread but can someone confirm that the crossover adjustment on this receiver is global for all speakers and does not have individual crossover adjustment for Front, Surround and Sub?
So, you basically get a single crossover adjustment that affects all speakers.
post #1580 of 4530
that would be true of ALL pioneer avr's...
post #1581 of 4530
I also think that the signal strength is not good enough for long length cable. Unfortunately I did not try other inputs (other than BD). Anyway, I also disabled deep color on the PS3 at the same time, so I am not sure whether diabling the deep color or reducing the cable length worked for me but it seems fine with shorter cable and disabled deep color.
Karun
post #1582 of 4530
Hi Karun
Al
ismatta, try disabling deep color on your BD player. I wish I had tested other inputs before moving to shorter wire.
post #1583 of 4530
I just purchased the new Apple TV and ran into 5.1 audio issues. The center channel audio is missing when the AVR show Digital audio. Left and right play fine. My IcontrilAV show the movie as Dolby PLII. Switching the receiver to stereo returns the actor's dialog. Is their any know issues with Pioneer and iTunes media? Thanks.
post #1584 of 4530
I just replaced a 6 year old Onkyo R520 with the Pioneer 1020k. The moment I connected the 2 front channels and my ps3 I turned it on to try it out. The difference was outstanding. I spent the next several hours listening to all my favorite songs "for the first time". I really wish I had purchased banana plugs- hooking up the speakers was very tedious.
post #1585 of 4530
hello people... I am a new soon to be vsx-1020-k owner.. it comes tomorrow.. this is my first new receiver in 8 years... finally bringing my system up to modern times. my current receiver is a yamaha rx-v1400... my speakers are BIC DV64's in the front and a Paradigm cc-270 center (but going to change that to a BIC DV62CLRS sometime soon) with 2 sets of Wharfedale WH2's for the surround sides and backs in a 7.1 config.. sub is a velodyne impact-10. I'm very excited to drop the 1020 into the mix and finally get TrueHD and DTS-HD surround modes.. anyways.. just a note to say "hi".. I am sure I will be lurking in this thread for a while..
post #1586 of 4530
I have a question about the VSX1020K..
I am about to pull the trigger (tonight) on the VSX, choose this receiver over the HT-RC260 from Onkyo (Hop ethis is the right decision)
Anyways, As far as the video processing, I heard that it is best to shut it off, but can I do that per port? Meaning I have a VCR (Wife still has some VCR tapes) that I need to run. I have a 3D BluRay player and a 3D enabled TV.. So is it possible to convert the VCR and run PURE on the other HDMI ports?
Also, Is there any "Got-ya"s that I need to be aware of?
Thanks for the input.
post #1587 of 4530
Think you're confusing threads. Pioneer does not degrade picture quality with video processing on. Moreover, you can set resolution per input.
post #1588 of 4530
Winston,
Read your review, Do you feel that the VSX is a better route than the RC260? I don't need ARC (Panodra from BDPS770) and stndby passthrough not needed either, 3D is as the display is a PN58C8000
Also, to "upconvert" do you need video procesing on? I would rather run PURE and let the Samsung do the processing.
Appreciated.
post #1589 of 4530
Does this lag happens when playing your BD playerr or only Dish or both?
Have you try turning on "A.Delay" under Audio Parameter?
This is very interesting. I have a PCH A-100 and sometimes if I stop what I am watching or pause it, upon restarting the lip sync can be very annoying.I wonder if the A-100 will work with this? Guess if it does not automatically fix it, I can try the manual setting. How does it know what to do as far as delay? Some shows are perfect even when stopping/pausing and some just go crazy..I think since it is not a constant thing, manual setting would be the only possibility.can't wait to try!
post #1590 of 4530
So, I just installed my new receiver with 3 speakers (2 satellites, 1 center) and a blu ray DVD player.
After about 1 hour of watching a movie, the receiver shut down and I saw a little bit of smoke come out of my receiver.
This looks really bad.
I double checked all the speaker wiring and it looks fine. This IS the first time I have done this so what I did was install banana plugs on all the wires and I matched all the red to red and black to black connections.
I'm using Aperion speakers and they are the right specifications. Did my speakers blow up my receiver?
