AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The "Official" Pioneer VSX-1020-K Owner's Thread
The "Official" Pioneer VSX-1020-K Owner's Thread - Page 104
post #3091 of 4365
Originally Posted by FM Fan View Post
Can someone tell me how to obtain the Receiver's IP address
Log into your router and see what address it assigned. Please don't ask how you do that since it varies by model of router.
post #3092 of 4365
The router will automatically assign an address. You can always go into the receiver and create a static address if necessary.
post #3093 of 4365
I will try that...but the Manual says the IP address for the Receiver is found on page 103...
Thanks for the help!
post #3094 of 4365
It will vary depending on the local network. Your router assigns it via DHCP. I think you can see it if you go to System Setup>Network Setup.
Pages 103-104 do describe the RANGE that the IP address need to be.
post #3095 of 4365
Help......I recently purchased a VSX 1020 K, had it all hooked up and working great. TV, Blue ray, IPOD all sounded great....came home today and noticed the center channel and sub were not putting out any sound. I went through the auto setup again, I can hear sound in the center and sub during the setup, but after that I could not. I figured it was something I hit on the remote, after searching awhile, I called Pioneer and the tech told me to set the advanced surround to ext. speaker, while this got me some sound, it was not as good as it was and I still have no sound when in auto surround. Any suggestions?? Thanks in advance......
post #3096 of 4365
What size do you have speakers set to? They should usually be set to small if you are using a powered sub. Do you get center channel on any source (TV, BD cable or SAT)? I had a bad center channel relay on my 1020 and had to have it repaired. It would take 20 minutes to warm up then the center channel would kick in. But if it works in the setup, it should work from the source too. Are you using HMDI for each source?
post #3097 of 4365
I do have the speakers set to small. Yesterday I had center and sub from everything I listened to, and yes, I have HDMI for Blue ray and my cable box. Makes me sick because it is only two weeks old, and I was just getting used to it and loved the sound.
post #3098 of 4365
Are you sure it's being fed 5.1?
post #3099 of 4365
Excuse my ignorance......I am new at this........what do you mean by fed 5.1?
post #3100 of 4365
Do they not work on Blu-Rays' too, or have you only tried it with TV? It's possible the TV shows you're watching don't have a sub channel or a center channel (only stereo).
post #3101 of 4365
I have tried various sources, but I do not have any dvds or blue rays here to try. There is a slight difference when I change channels on the tv, but I just tried some music that I listened to yesterday, "The Thunder Rolls" by Garth Brooks, the bass yesterday scared my daughter and today there was none.
post #3102 of 4365
Is there a way to switch from the A Speakers to the B Speakers on the remote or can this only be done on the front of the receiver? Thanks.
post #3103 of 4365
Two disappointing iOS apps from Pioneer today. iControlAV2 and AirJam. They are only compatible with the new VSX-1021-k.
While looking at these 2 apps I went back and read the reviews for the original iControlAV 3.1.0. MULTIPLE people said they could power ON the VSX-1020-k with the app by setting up the receiver's network to work in standby mode. I doubt they are lying, but I haven't found a way to do this and the app directs me to manually power the 1020 back on to use the app again.
Anyone have instructions on powering up from standby with iControlAV 3.1.0? Or can anyone in this forum actually do this?
http://m.engadget.com/default/articl...sic&postPage=1
post #3104 of 4365
Hey everyone - with the recent release of some of the 1021-k specs and intitial MSRP (~$550, i think) - do you expect the price on the 1020-k to fall further?
Right now it's very reasonable in the $360-370 range from various online retailers. I've been teetering on the cliff's edge at that price point, however am curious if a further price drop is expected (and how soon/long it will take).
Any thoughts?
post #3105 of 4365
Re: 1021: While the airplay functionality is nice, I can already do this with an airport express I have hooked up. I could also just buy an Apple TV for $100 and do the same thing. I know it is nice to have it integrated in the receiver, but not a deal breaker.
The unfortunate thing is how Pioneer released the iControlAV2 and left the original users in the dust. No iPad full screen for iControlAV1 users. It's unfortunate, but possibly they will update it in the near future. I don't see why they needed a separate app. I wonder if they will enable the receiver to actually be powered on by the new iControlAV2 app?
post #3106 of 4365
I say flood the app store with negative reviews stating that it doesn’t work with the 1020 and that the original app has been abandon. Maybe we can shame Pioneer into doing the right thing and updating as many features as are compatible with the iPhone app and the 1020.
post #3107 of 4365
If I knew that would work, I would do it, but I doubt it will make any difference. I'll write a review though and let them know what I think.
post #3108 of 4365
One can always dream.
post #3109 of 4365
Originally Posted by bootman_head_fi View Post
Doth bother with bi-wiring.
Its nothing more than a marketing gimmick to get you to just buy more wires.
http://www.nousaine.com/pdfs/Wired%20Wisdom.pdf
Yea I ended up moving the 702's to the rear and put some M74 speakers up front and bi-amped those.
post #3110 of 4365
Perhaps Pioneer is taking a lesson from Apple in yearly obsolescence.
About the VSX-1021,
"Compared to the other AirPlay-compatible receivers from Denon, which cost upwards of a $1000, this Pioneer box could be a steal. Especially considering the HDMI 1.5 support (allowing multiple DLNA connections at once) and custom iOS apps that enhance its functionality in many ways."
Read the whole story here:
http://ca.gizmodo.com/5779048/pionee...ctually-afford
Note: for those that hate Gawker media's new face lift just put a ca instead of www in front to keep the old format.
lol, guess some folks beat me to it.
post #3111 of 4365
Being as I have no use for AirPlay I guess now is the time I should start looking for a used or refurbed 1020.
post #3112 of 4365
BUMP. Does anyone know??
post #3113 of 4365
I really don't think so. I use this feature a lot, but haven't found a way to switch to speakers A or B on the remote yet. Maybe the new I-Phone app will have it, but we'll be out of luck if they don't offer compatibility for 1020-K systems.
But, I still love my 1020-K! Despite its flaws, which there are usually workarounds for, and despite its complicated remote, which is actually great when you get used to it, it all looks sweet, works well and sounds amazing. How about that EXT. STEREO mode? Just wonderful!
post #3114 of 4365
I don't use different speakers other than my main speakers, so I can't say for sure, but I have an MX-900 remote and the program to set it up lists all the codes you can program the remote with.
It lists the following speaker related codes:
Speakers A ON
Speakers B ON
Speakers A+B ON
Speakers OFF
Speakers
It looks promising for what you are looking for with a programmable remote.
post #3115 of 4365
Any thoughts?
It's a great deal at that price. Go for it. Or wait a month and hopefully you can find it on even lower clearance price somewhere. I have the 1020 & love it. Wish it worked with the v.2 iPad app, but it works ok with the v.1 iPhone app. AirPlay is no big deal if you have an AppleTV, which will do AirPlay anyway.
post #3116 of 4365
Just speculation, but I bet the 1020 will work fine with the v.2 app. Why would Pioneer want to enable it while the 1020's at $360 and the 1021's are now hitting the streets at $550? I don't see $190 extra value in the 1021. maybe once the 1020 is officially discontinued we'll get an upgrade in the app.
post #3117 of 4365
Speakers A ON
Speakers B ON
Speakers A+B ON
Speakers OFF
Speakers
That is GREAT to know. THANKS!
post #3118 of 4365
In the Pioneer product specification page, it says VSK-1020-K is compatible with the iControlAV2 iPhone and ipad Application.
http://www.pioneerelectronics.com/PU...ers/VSX-1020-K
I just got my 1020 only a few days, and I can still return it and wait for the 1021. But if I can use the app and I already has AppleTV, I guess I am fine with 1020.
post #3119 of 4365
http://www.pioneerelectronics.com/PU...ers/VSX-1021-K
That's the link for the 1021. 1020 makes no mention of iControlAV2 support.
post #3120 of 4365
That's a good point. 1021 still has airplay which I don't think will ever work with the 1020 though.
