Originally Posted by
ben_r_
Ill add my two cents to this thread FWIW.
I have both the Sennheiser HD-650 and Denon AH-D5000 headphones as I find that the two compliment each other well. The Denons are there for me when Im listening to music that has a lot of bass and the Sennheisers are wonderful for everything else.
Nice choice of cans.
I've both Sennheiser 600 and 650, but they're too similar. Meaning that I think your choice makes more sense.
i.e. having two cans that are enough different, coz no one can works with all music.
One other, in this thread, did a similar comparison between Sennheiser and Denon cans. I think the Denon 7000 his specific Denon. It was very clear from reading his review that certain stereo music (from CD discs) works far better on one headphone and not the other.
ben_r_
I power them both right now with a NuForce Icon HDP amp/DAC and just ordered a Yulong D100 MKII amp/DAC to possible replace the HDP. Havent gotten a chance to compare the two yet though.
I also have a NuForce Icon HDP amp/DAC and rather like it. Why are you going to the Yulong D100 MKII amp/DAC to replace the HDP?
I recently got a Benchmark DAC1 HDR for headphone use, and while I like it better, I'm going to hang onto the NuForce Icon HDP.
The only negative thing about the NuForce Icon HDP is that in summer when my room temperature gets to 80+ F, then the NuForce Icon HDP metal case gets alarmingly warm/hot.
The metal case of the Benchmark DAC1 HDR also gets warm, so I'll find out how hot it really gets on a warm day in the next 3 months.
For others, physical dimensions of case/feet/knobs:
Benchmark DAC1 HDR is: 9.3" x 8" x 2"
NuForce Icon HDP (no feet) is: 6" x 4.25" x 1.25"
ben_r_
My source is a Logitech Squeezebox Touch fed into the amp/DAC via S/PDIF optical.
My main source is a decent PC, sending .flac files (high quality 16/44.1 rips from the original CD discs) via digital coax (S\\PDIF) out from the built-in mobo sound circuitry and software driver.
I've found that digital S\\PDIF via a good *coax* digital S\\PDIF cable generally sounds better than either Toslink (optical) or USB digital cables; but haven't revisited that now that I have the Benchmark DAC1 HDR.
ben_r_
I enjoy my headphone system(s) very much and am glad I made the investment.
Ditto.
