OK, I can confirm that the service code works, or some variation of it
The reason I say this is because it took me about 50 tries, and by this time I finally got in, it has to be done on the set itself and what makes this incrediblity difficult are the dumb touch sensitive buttons
But, i think this is how it goes, put tv on TV input, unplug 1 min, plug back in, press and hold vol -, meni, and power when turning on (note Im not sure if you have to hold the power button or you can release it, these dumb buttons almost made this impossible to figure out) the tv whille come up with a K and model number on it, you then press and hold vol- and channel - at same time, this goes into service menu
To exit just turn off/press power
Whats in the service menu? well no video selection for USB that I saw/hoped for
But there are lots of adjustments for picture and brightness of items, such as the from LED, the volume and channel indicaters, test patterns, lots of stuff I have no clue what it is, lots of info on the ROMs and BOOT stuff, ect ect ect but no option to turn on the video playback from USB that I saw
Bottom line, if youre trying to do this and dont get it on the first time, keep trying, these buttons almost make it impossible but give alittle effort and youll eventually get it, why they didnt use the remote is beyond me
Edit:
Yes a firmware upgrade today
This Firmware Update improves performance of Netflix, AQUOS Net and AQUOS Advantage features.
This update includes all previous fixes and improvements.
Version: U1011171
Date: 12/08/2010
Edit:
Version: U1011171
Date: 12/08/2010
