AVS › AVS Forum › Audio › Receivers, Amps, and Processors › How to DIY ; TX-SR576/TX-SR606/etc HDMI daughterboard repair (for dummies?)
How to DIY ; TX-SR576/TX-SR606/etc HDMI daughterboard repair (for dummies?) - Page 14
post #391 of 806
Originally Posted by EvlAsh View Post
The cap that they used was 100 microfarads 16v
Thanks so much! Great pics. Will give it a try once my OSD completely craps out.
post #392 of 806
Originally Posted by Makrel Johnson View Post
UPDATE: I cleaned and re-soldered (re-heated) all my joints and this time the good picture lasted for hours. 30 min into playing the PS3 I lost the quality and I'm back to Blue/Magenta screen. At this point I'm going to assume it's heat and treat as such. I have a fan all ready to mount and piggy back off the 5 pin HDMI board power plug, just need to do so.
-Makrel
Update to Update: Seemed to be a PS3 Deep Color Bug. I disabled it and have had no issues. I never got OSD back but then I really hardly go into the setup.
I have another dozen caps coming to replace the last 2 I harvested from a motherboard then I'll call it 'repaired'. I'm going to go back and scour the thread for OSD info and see if I missed anything. On the bright side, this 'allowed' me to get a nice Aoyue 937+ station for being on a circuit board repair kick... beat the heck out of my old Shack Pencil and trying to use my 140 watt Weller gun
Thanks Again to Everyone providing info on getting this fixed!
post #393 of 806
Makrel,
If you ever go into your receiver again, check the cap on the underside of the board. What I found is that there is a cable pushing up from below that partially dislodged my cap the first time I replaced the board after soldering the caps in. I wound up bending the cap more flat, with respect to the board, and doing a better job of soldering. I don't know if that will fix the OSD issue, but it's worth checking.
post #394 of 806
Just some extra info for you guys, I have been having the same issue , except that my warranty expired about 10 months ago, before trying to fix it myself i called in to onkyo and they told me to fax them the receipt and contact info and that they would send me an authorization number to get it fixed by a service location in my area.
Still trying to get a copy of my Bill but seems all will work out. So try giving them a call first to see what they say.
post #395 of 806
Makrel - are you getting 1080p out of your PS3?
post #396 of 806
I have 606 and xbox connected via HDMI. After i have replaced all 100uF caps, installed 1uF caps to regulators i have fixed "no osd/picture" issue, but i have strong blue saturation on tv. Didn't found in this thread if someone from you have faced this problem too and what can be solution for it?
post #397 of 806
PS3 @ 1080P? I do believe so but can't be sure. The 606 is set for pass through and the PS3 is on the Aux HDMI input. It looks pretty sharp and smooth. I guess it could be 1080i though.
I just pulled the board and re-soldered all the caps again and still no OSD. Going to go back through and see if I missed anything. maybe I got a bum cap in there somewhere. The caps are Digi-Key 565-3047-ND (mfr:APSA100ELL101MFA5G)
Here's 2 images of my handiwork... notice the 'worn' look of the 220's 8076,8683 and271. Might hit those up next.
post #398 of 806
karel_007 - I had that result and thought I screwed up a solder joint.
It only occurred when I used the PS3 after 15 minutes of up time - never happened on Satellite input or DVD. I turned off Deep Color on the PS3 and it hasn't happened since and it's been burning in for maybe 20 hours.
Go to Settings > Display Settings > Deep Color/Colour Output (HDMI) and switch that puppy off. That oughta do it.
post #399 of 806
I have tried to resolder it for 3times and still same result. Going to buy same parts again and do it for 4time.
About PS3: I have xbox, but anyway same blue saturation on all inputs which i tried(pc-hdmi, phone-cinch)
post #400 of 806
Makrel,
Check out my last post (#389) on the previous page -- maybe it might help. Anyway, that was done by the service center that I took my 606 to. They were supposed to fix the HDMI issue, but only fixed the OSD and called it a day. I eventually ended up doing the repair my self.
post #401 of 806
EvilAsh - I put one of my aluminum caps like the shop did and I'm still w/o Component and OSD. (And sheesh they use much flux?) Is that Nichicon non-polar? I can't tell from the pics. Maybe I have mine reversed (it's polar) or maybe I need one like you've shown us.
I'll see if I can snap a new pic this weekend. Maybe I'll hit up radio shack at work and see if I can get a 100. I used to have these things all over when I was working in custom car audio. They were like sawdust, everywhere. Now they're scarce when I really need them
post #402 of 806
Originally Posted by Jon S View Post
the 876/906 uses the HQV video processor... the HDMI board is a LOT more complex and expensive compared to the other models. I have asked if anyone has done any mods to see if they got it working but no response/luck.... guess it's because not many of the 876/906s were sold compared to the cheaper models...
After doing tons of research, I just managed to SUCCESSFULLY repair my TX-SR876 HDMI issues by applying the method and techniques discussed in this thread. I learned of the success people had repairing the 606 by replacing the 100uf caps, which appeared to be identical to the ones utilized on the 876 board. However, I could not find an example where someone had actually tried it on their 876. I figured I had nothing to lose by trying, since the HDMI inputs were all but useless. I had to wait 30 minutes before the receiver would recognize an HDMI signal. Most of the time i simply received a "NO SIGNAL" message.
There are 13 of the same 100uf 4V caps on the 876 HDMI board. 5 on the top and 8 on the bottom side.
I replaced each of the 100uf 4V capacitors with high-temp 100uF 16V caps I purchased from parts express.
After reinstalling the board and crossing my fingers, low and behold, SUCCESS! HDMI sync and switching works just like the day I bought the receiver. SO happy.
post #403 of 806
Just completed by fix and everything is working well again. The first time I put things together though it did not work. After some trouble shooting I found that one of the ground pins from the 5 wire plug had come loose. I re-soldered it and all was well. Something to look for if you are still having issues.
post #404 of 806
Getting ready to do this repair and I noticed that some people mention replacing a single 220uf (or is it a 22uf?) cap in addition to the 100uf's. Which cap are they talking about? Is this necessary or is it the consensus that replacing the 100uf's and adding the 1uf's to the regulators is sufficient?
post #405 of 806
Scottie 2 thanks for your post..., my 876 is still running without problems but I'm watching this thread closely. I only expect the worst with this receiver. I've been lucky so far.
post #406 of 806
I would check all electrolytic caps with a temperature rating of 85°C, whcih seems to be insufficient on the HDMI board.
post #407 of 806
Quick update, brought my TX-SR606 to repair shop and onkyo replaced HDMI board completely with a new one (1B211573-1A1, GENESIS chip on it). and i was 8 months Past warranty expiration.
Works Flawless now. For how long? I dunno
post #408 of 806
DoBoY,
Wow! That's a new one. Any cost to you? I see where these cards cost about $230! Sounds like you got a great deal. Did the repair shop charge you any labor? Did the replacement card come with any sort of warranty? How could your receiver be only 8 months out of warranty? When did you buy it?
Curious minds would like to know . . .
post #409 of 806
Originally Posted by DBacksFan5205 View Post
DoBoY,
Absolutely no cost to me, no labour either, all paid for by onkyo. I bought it in march 2009. All onkyo wanted was proof of purchase from an authorized shop and I was good to go, all I sent them was an email with an invoice # from an on line Shop.
No warranty that I know of but that might have been asking a little much Either way i will prob add a cooling fan on mine to make sure i can stretch out the life of this one. I do have a wide open area around the receiver but adding the fan can't hurt.
Im pretty pleased with Onkyo's support on this issue. Still it was a faulty product.
post #410 of 806
I have a 706 and the HDMI inputs were not working at all... I replaced all 12 caps and like magic it is working great! Huge thanks to CZ_the_DAY and everyone else for all the great info!
I have one problem though... I broke the power connector. You know the white plastic piece that goes over the 5 metal clips and has a top piece with 5 small holes in it for the five small wires, the one in CZs first picture. Well I wasn't sure how it came off (should have read more) and I broke one of the sides of the top connecter piece, so I can't get the wires to securely stay down against the clips now.
Thinking I could just use some electrical tape and tape it down. Or anyone know where I can order another one of these plastic connecter pieces? Or I could get a bit extreme and solder the power wires to the metal connecters.
Any ideas or recommendations?
Thanks again everyone for all the great information and help!
post #411 of 806
Not exactly what it looks like since I haven't done mine, but I've fixed other things similar with a hot melt glue gun. Could you put the connector in place and then glue it with the hot melt?
post #412 of 806
Originally Posted by igo4bmx View Post
UPDATE
got it working perfectly!
if you have problems where the receiver keeps trying to reconnect to a device you HAVE to replace the left most capacitor in this pic
Originally Posted by Kris404 View Post
SUCCESS!! YAY!!
HDMI handshaking works perfectly on my HT-R960, no more waiting for the receiver to warm up (mine was totally dead btw)
OSD also works now. Switching works great - LG BD390 BD Player, Apple TV 2G, ASRock ION330 HTPC
Here is a stupid mistake I made: The initial 100uf 4 cap replacement may have fixed my issues since I did not realize the HDMI-out cable into the TV was loose. I guess you live and learn
This what I ended up doing after the initial 4 cap replacement didn't seem to work:
- Replaced all 100uf caps (10 caps: 8 on the back, 2 on the front)
- Added 5 x 1uf 50v caps across the regulators (4 on the back, 1 on the front)
- Replaced 1 x 220uf 16v (back, far left)
Thanks a lot CZ, you saved me atleast $1200 I almost ordered the 3311CI
Kris
Specifically I'm wondering why the above two guys talked about replacing the left most 220uf on the back side. Any ideas?
post #413 of 806
Thanks for the tip Burnerbum... I think I will try that. Just hope the pins make connection after placing the glue . Thanks!
post #414 of 806
Hi everyone, joined the forum just to to say thanks and share my experience with other members.
I have a 906 with the same HDMI connection problems everyone else is experimenting. After reading this threat I decided to replace all 100u caps and voila, everything's working as in day one!
I didn't take any pictures because the board is the same as the 876 board that Scottie2 posted a few posts back and I basically did the same he did.
So, as a confirmation, this fix will also repair a TX-NR906.
My most grateful thanks to CZ_the_DAY and everyone else!
post #415 of 806
Another win! My 606 has been getting worse and worse on BlueRay, and beginning to fail on 720p. I was about to replace it, and found this thread.
I replaced the 4 caps, managed to get the HDMI board out and back in again without breaking anything. And now, Joy! The Oppo works again, the Tivos too.
Thanks CZ and everyone else who shared their experience and tricks to make this work.
post #416 of 806
After doing tons of research, I just managed to SUCCESSFULLY repair my TX-SR876 HDMI issues...
Thank you for the detailed notes and pictures! I still have no problems with my TX-SR876 (with cooling fans on top since the week I bought it), but now I know I should be able to fix this issue when (probably not "if") it happens. (I work in an industry with plenty of heat-related capacitor failures, and almost always, improved cooling delays this kind of failure but does not eliminate it. This week, I expect to replace some caps in video monitors that have stayed cool for about ten years of continuous use, while the monitors that got hot needed repairs after only one to four years.)
post #417 of 806
Originally Posted by FEARDIZ View Post
Where does the C8602 neg. side connect to?
I had the same problem with C8602. The positive solder pad got pulled off. Can anyone help me figure a way to fix it? From some of the things I have read I think it would be ok to solder it with Q8651 as long as polarity is kept right.
Otherwise I did the repair. Replaced 9 of the 10 caps with 35v and 50v 100uf Radio Shack caps. My component through HDMI works and OSD, but not getting any video or audio through HDMI 1-4. Before I did the repair it would say no signal on the receiver, but that is gone. The light for HDMI shows up on the receiver, but my tv still shows no signal.
Do you think its because I still have everything set to 1080p as everyone else is saying that it may not except 1080p even after repairs.
post #418 of 806
Hi all, great work to all who contributed in this thread!
I was on the verge of trashing the onkyo because of this problem (and much longer story of various incompatibilities) before finding this thread.
I replaced 6 caps 8072, 8096, 8602, 8607, 8609, 8162 and the "needs to warm up before any picture" problem is solved.
However after a few hours of use I got exactly the same problem as karel_007 in post 396.
I'm going to re-solder all the caps I installed as this blue/magenta problem never occurred before the cap replacement. I'll update if I find a permanent fix.
If anyone has any ideas of what to look for please chime in!
post #419 of 806
Well I replaced the 100uf's and added the 1uf's to the regulators (which was hella difficult btw, needed a LOT of solder and it's still not very secure). HDMI switching is fast but still no OSD. I can live without the OSD so I'm pretty happy. I'll probably try adding a couple of fans to keep things cool.
post #420 of 806
Pardon the long post, I think this is a noteworthy observation.
For a month or so now, my Roku connected via component usually would 'white' out after an hr or so of inactivity. just a white screen. Switching to another input and then back would bring it back. Or sometimes I would be watching netflix or anything on component (either DVD or Roku) and on random occasion the top 5% of the screen would show artifacts, eventually leading to a screen whiteout. Again, switching inputs and back would bring it back to life. Recently, last week/ weekend marathon of Uncharted 3 and not turning off the unit for 5 days in a row I notice the OSD went kaput. Nothing serious going on with the PS3, HDMI inputs were all good. Composite inputs died as well. I figured maybe the repair has finally broke down and the unit went bonkers again. Instead of re-replacing all 4 caps, this time I figured go at it one at a time. I started with C8602. Visually, it looked like it was bloated a bit so that's what led me to start with that one. Replaced JUST THAT ONE and it is up and running again. So be sure to follow CZ_THE_DAY's recommendation to use auxiliary cooling. I may even extend the leads so that this particular capacitor is situated either closer to the side of the unit or that it is situated on the top side of the daughterboard, because the airspace of C8602 happens to be in the vicinity of a heatsink from the lower card. Since I got 3 of those caps as backup, I think I can experiment with ideal placement of that capacitor, should it die again (or I can return the 3 caps to rad shack so I have lunch money LOL)
Bottom line - the rad shack capacitors work fine for this purpose, it's lasted me over a yr now. Just remember to ventilate, or the one you replace for C8602 won't last very long...
