AVS › AVS Forum › HDTV › HDTV Recorders › DirecTV HD DVR - HR2*/ HR34 Master Topic: one thread for all
DirecTV HD DVR - HR2*/ HR34 Master Topic: one thread for all - Page 68
post #2011 of 2014
Originally Posted by cosmos5861 View Post
If I turn off Dolby then I will only get Stereo?
Ok I did turned off Dolby Digital and the problem is gone but I only get stereo to soundbar even if the program is Dolby Digital!
post #2012 of 2014
Does it sound good. That's about the only thing important in a sound system. I know the sound bar is a very pricey setup and if you have what google took me to its says its 5.1, I just can't by it that a sound bar can put out real surround, need some back speakers.
post #2013 of 2014
No not even close to Dolby Digital.
post #2014 of 2014
Cloning a 1tb to a 2tb external drive. I have done several tivos without problems but I cant clone a 1tb Direct TV to a 2TB direct TV drive and expand the main partition to the 2tb. In other words I can use one of several partition programs to clone the 1tb to the 2tb but I end up with a 1tb main partition. I cant expand it to the full 2tb. The first 2 partitions are on and the big one works and plays but I still end up with a 1tb. I found a thread where some guy used gparted 3.7 older version to copy the partition and expand it but I cant get it to work for me. Here is the thread. Ive tried it 3 times now and it never copies the partition. It just says successful. Is this a 0 (zero) or a o . mount -t xfs -o rtdev=/dev/sda3 /dev/sda2 /mnt/fap, I tried it both ways. Does anyone know of other threads or a cloning program that will allow me to expand the big partition? i have tried most. I think the partitions are linux.
Here are the step-by-step procedures I took:
Try to do a graceful shutdown of your DVR through the menu system. For me, this was kind of hard because in the menu there is a reset option and I believe that between time I went through the reset sequence and got to my DVR to unplug it, it had started the boot up process. This can lead to a "Can't Read Superblock" error which interferes with the copy process, but can be overcome.
Unplug your old external drive from the DVR and plug in your blank new drive.
Reboot the DVR and allow the DirecTV software to be loaded on the new drive.
After the DVR has booted up, follow the same steps as #1 above to shut down the DVR.
Unplug the new drive from the DVR.
Download gparted from the link above and create a bootable CD or usb drive.
Install your old and new drives into a computer. The instructions on dbstalk state to use SATA port 0 for your new drive and SATA port 1 for the old one, but I don't think it really matters as long as you know which one is which when it comes time to copying. But if you can install the drives as stated above, I would recommend it so there is no confusion on the drive letters for the steps below.
Boot the computer from the CD or usb drive.
Go to Devices from the gparted menu and make sure both of your drives are showing up. If you used SATA port 0 for your new drive and SATA port 1 for the old one, then the new drive should show up as sda and the old one as sdb. If these are different, please note the drive number and substitute the appropriate drive letter for "a" or "b" instead of sda or sdb in the instructions below.
Double click on the Terminal Icon to open the terminal window. This will allow you to manually enter in some commands.
I had the "Can't Read Superblock" error, so I had to do this extra step. It shouldn't hurt to run this command regardless of having the error or not, so if you want, just go ahead and run it first without finding out if you have the error or not. xfs_repair -L -r /dev/sd?3 /dev/sd?2 (where ? is the letter of the drive with the error). I ran it on both drives, so I substituted a for both ? the first time and b for both ? the second time. If your drives are not sda and sdb, then make sure you use the appropriate drive letter.
Type in mkdir /mnt/fap and press enter.
Type in mkdir /mnt/hr20 and press enter.
Type in mount -t xfs -o rtdev=/dev/sda3 /dev/sda2 /mnt/fap and press enter. This is mounting your NEW drive, so make sure you change from sda to sd if your new drive was not listed as sda in step 9 above.
Type in mount -t xfs -o rtdev=/dev/sdb3 /dev/sdb2 /mnt/hr20 and press enter. This is mounting your OLD drive, so make sure you change from sdb to sd if your old drive was not listed as sdb in step 9 above.
Now the command instructions to copy all your data from one drive to another. At the command prompt type in xfsdump -J - /mnt/hr20 | xfsrestore -J - /mnt/fap and press enter. A whole bunch of stuff will scroll on the screen and the last thing it will say is restoring non-directory files. Depending upon the amount of recordings you have, this step will take many hours.
Finally it finishes and a message is displayed that reads Restore Status: SUCCESS.
At the command prompt type in umount /mnt/hr20 and press enter.
At the command prompt type in umount /mnt/fap and press enter.
Type exit and press enter to close the terminal window.
Double click on the Exit icon.
Click on Shutdown and OK.
Remove the disc or usb drive and press enter. Power should be shut off. Make sure the power is off. Unplug the PC if you are unsure.
After the power is shut off, remove the disks from your computer.
Install the new disk into your external enclosure, plug it back into your DVR and reboot your DVR. After it has booted up, you should have an exact copy of all the settings and recordings you had before with extra disk space.
  Back to Forum: HDTV Recorders
