AVS › AVS Forum › HDTV › HDTV Recorders › DirecTV HD DVR - HR2*/ HR34 Master Topic: one thread for all
DirecTV HD DVR - HR2*/ HR34 Master Topic: one thread for all - Page 4
post #91 of 1949
My two HR-21s, also frozen are fine after 2 reboots which need to be within 30 minutes to clear the cache.
After reboot, the system info indicates an upgrade was made at 3:30am overnight.
--HG
post #92 of 1949
Originally Posted by Budget_HT View Post
My HR22 and HR23 both required power down/up this morning. So far, both working after one power cycle.
Had to do another power cycle on each.
post #93 of 1949
No dice here. Trying to get through to Dtv tech support for service call. Ima smash my DVR soon.
post #94 of 1949
calling D* will not help much
I did notice that even after the two reboots I had to hit the commands a few times until it started to respond
post #95 of 1949
Many are reporting that the two RBR method works. I just did it with my HR20-700, and it worked fine.
post #96 of 1949
I just got the download for my oldest HR20: worked fine with no reboots needed
maybe they resolved the issue?
post #97 of 1949
Same here with my HR23. It's easy to criticize but it is hard to understand how this doube clutch was missed in beta testing. For a lot of D* users who don't read this or other threads, D* CSRs will be inundated. A PR fiasco.
Dana
post #98 of 1949
The consensus is this:
Affects ALL DVRs.
The fault was related to corrupted guide data (again!). The last update cycle started 5/20, so the update itself was not the immediate cause (leaving aside the "letting corrupt data through" issue).
The common symptom is remote doesn't work, stuck on one channel.
Two complete red-button-resets are required within 30 minutes to flush guide data.
edit: I should add that this was my exact experience on an HR20-700 & an HR21-700
post #99 of 1949
Affects ALL DVRs.
Only thing I see different [or to add] is my HR24 wasn't affected, while my HR20s were.
post #100 of 1949
Originally Posted by drbonbi View Post
... but it is hard to understand how this doube clutch was missed in beta testing.
Perhaps beta testing neglected to test with this week's guide data.
post #101 of 1949
HR20-700: Got the new 3D message then black screen. TWO RBR and all is well.
New HR24: No message of anything new and it worked fine during the time the HR20 did not.
post #102 of 1949
just as a bit of background:
I joined AVS in 2001 because my new DirecTV boxes were dropping out every half hour: I searched everywhere for a solution and found nothing til I came here to AVS to learn it was a known issue: D* had a software glitch and it screwed up the box: a new download fixed it a few days later
same D*: different day
post #103 of 1949
Nothing is perfect and I will never switch back to ComCrap.
post #104 of 1949
recently I reactivated my Comcast HD service to see how they compared: I was having outages with D* during bad weather but that turned out to be an issue with the sat dish that D* fixed under my service contract.
Comcast has come a long way back in PQ and customer service: and they will dispatch a technician a lot quicker to respond to a problem.
D* screwed this up and owes its customers something to make up for the disruption: as you point out, nothing is perfect
I have been waiting years for FIOS service: I was assured of FIOS to my home several years ago as a Councilman when we approved the FIOS request to lay fiber, only to find out they have no funding left to run fiber down my street even though most of my town has it
post #105 of 1949
So does 0x3df come after 0x3de? That's what on my HR20-700 right now and it's working fine.
post #106 of 1949
There is NO update related to this.
DirecTV is now sending "reboot" signals to everyone it seems.
post #107 of 1949
Not so fast!
My "all is well" statement above appears to have been premature. That was hours ago, and the updating of the HR20's schedule is going painfully slow.
How slow?
Wednesday's schedule still has holes and nothing shows past Wed.
and ...
navigation is SLOW, SLOW, SLOW
All is NOT well.
post #108 of 1949
My two HR 22s seem to be working OK now, but I've found the power on on both of them when I had not turned them on.
Also, when running a system test, I am told that my receivers are configured for the incorrect satellite dish. Repeating satellite setup and choosing the correct dish does not change this message, but everything seems to work OK.
post #109 of 1949
My HR21-700 locked up today like everyone else...funny thing is I got the update on 6/2 at 7:28 AM...why the wait to lock up...
post #110 of 1949
I didn't leave ComCrap due to PQ (although they still do not use MPEG4 compression which looks much better than anything I received through ComCrap). I left because:
-They do not charge everyone the same. Anyone can call and complain and depending on the CSR you get different discounts. The discounts vary wildly. If you call and try to get the same discounts as someone else, they tell you that the other person is mistaken; those discounts don't exist.
-They do not upgrade their equipment or services. For example, they still use give out the original Moto DVRs. They upgraded the software on their DVRs once that I am aware of since 2002-ish.
-They add new HD channels as slow as possible.
-They refuse to become efficient at handling cable cards; making Tivo use nearly impossible.
-Their customer service is the worst in the business. For example, I had internet issues, they troubleshooted it, and decided there was an issue with the "tap" in my front lawn. They scheduled a tech to come out. I took a day off work, waiting for hours, the tech came (late as always), looked at for 2 minutes, and proceeded to tell me that a higher-level tech was needed and that I would have to call schedule another tech (and take another day off work). I could type for the next six hours listing situations just like this one.
-They do as little as possible because they know they have a monopoly on tv services in most areas. They know that many people do not want a dish on their house and do not want service to go out in severe weather. They have no reason to try and be the best company possible.
Back on topic...
I switched to DirecTV and haven't looked back. My only complaints are less than stellar subcontractors for installs and the rising cost of Sunday Ticket. I love their DVRs and their commitment to improvement.
post #111 of 1949
Originally Posted by pestocat View Post
I Just received a replacement for my HR23/700 receiver. The old one had problems after latest upgrade (my thoughts). I work with my internet ISP for service and to them, they said it was the fault of the receiver. Problem was that frames seem to be missing every second or so. New one works fine except software is dated 11/5 (Ox3a8), latest is at least 0x3de. Anyone know how it takes for the system to find out I have 6 month old firmware.
Thank you
Received my 0x3de firmware update early this AM. Everything seems to be working OK. No studdering. All my saved programs are there and schedule OK too.
post #112 of 1949
Ha, this was quite a funny read. People freaking out that their boxes aren't working, and within 10 posts, all is well. Guess it "sucks" that I don't want daytime TV and work during normal business hours. Didn't notice a thing...
post #113 of 1949
About 12:30 AM EDT, I received this message via email which is also posted online.
You may have experienced a transmission glitch to your DIRECTV service. DIRECTV has fixed the problem and automatically reset the receivers. There's nothing further that you need to do. We sincerely apologize for any inconvenience this technical issue has caused.
Our promise is to provide you with the best television experience, and to resolve any issues that might arise as quickly as possible.
Thank you for being a valued DIRECTV customer.
Obviously, a good thing that the glitch was fixed fast. The only thing better would have been that it didn't happen in the first place.
Dana
post #114 of 1949
Originally Posted by HDFinder View Post
It will display the squares for the icons, however almost all thumbnails are yellow warning triangles with the exclamation mark in it.
I think it's a DirecTV software bug, and there's nothing you can do about it. I can't say about the exact range of symptoms you mention, but the yellow error triangles turning up in place of thumbnails for WMP11 running on Vista started happening last Fall. It was reported by several of us to DirecTV. Maybe they'll get around to fixing it -- who knows? I haven't heard about this bug (one way or the other) with other server programs, like Tversity or Twonkymedia.
post #115 of 1949
Hey folks,
I wonder if anybody has any suggestions as to how I can get Media Share with my pictures to work. Video has never worked because I haven't downloaded the proper software. Music will share, and pictures used to share.
I can't think of anything that would have caused the picture sharing to quit functioning. Generally it's extremely slow to execute the menu system and when I select pictures I receive a multitude of errors. Sometimes it tells me the folder is empty. Sometimes it's Cannot Play Media. It will display the squares for the icons, however almost all thumbnails are yellow warning triangles with the exclamation mark in it. I can still continue to drill down into folders at times if I do want to. However when I choose to play a picture such as shuffle all or play all, it may actually display an image. The following image says something to the effect of cannot display image. It then switches over to grabbing content and usually fails again. Sometimes when I select "pictures" from the menu it will lock up the receiver and I have to RBR as it's completely unresponsive.
The receiver is only a couple of years old. I'm on a different router now than I was previously however I do believe my pictures were failing on my previous router also. I can't seem to understand why it may choose to attempt to load pictures sometiems, and not another. If picture do load, I only see one and I receive the unable to display, and it fails again on Grabbing content.
I have the HR21 connected with an AM21 (off air tuner).
Do I somehow need to change sharing on my PC or something else PC related? Thanks for any ideas you can provide.
Actually it looks like Vista SP2 changed how things operate with WMP. Start up a Media Share session to view pictures then look at the system error logs on the PC and you'll see a bunch of errors. This problem doesn't happen with Windows XP or Win/7 systems or Vista prior to SP2. A workaround is to use someother program as the service like TVersity or upgrade to Win/7.
post #116 of 1949
Called D* to see if they would give me a deal to swap out my HR10 for an HR24. They said the best they could do was $149, with professional install. Tried to get them to give me a credit to buy it myself at BB, but no go. Didn't really want the HR24, as my HR20s are doing fine now, so I passed.
I called again today to ask about the "enroll in bill pay, HD free for life" deal they are offering new subscribers. He said he couldn't find that offer, but he'd give me $10 off for a year anyway. So now I wonder I should call again and ask about enrolling and getting the $10, maybe score it twice for a year!
post #117 of 1949
Front line phone reps have very limited discretion. If you have been a D* sub for a while, call Cust Retention directly at 800-824-9077 and ask if they will help you upgrade. It is likely they will which also will extend your commitment.
AFAIK, BB isn't carrying the HR24. In any event, I have gotten deals where I "bought" the model I wanted directly and D* credited my account $100. once it was activated. They also sent a recovery box for the unit no longer in use.
Dana
post #118 of 1949
I notice the specs for the HR-24 mention 1080P. Specs on my HR21-Pro's state 1080 I.
Is is accurate that the Hr-24 upgrades the signal from 1080I to 1080I over the HR21-Pro? Are the DTV birds actually sending 1080P signals?
FWIW, hope I'm not breaking any rules here, but you can already buy the HR-24 online with 2 TB HD's installed.
post #119 of 1949
Your HR21Pro should also do 1080p, they came out with a software update over a year ago to add the support. Go to the HDTV Resolutions settings on the receiver, enable 1080p and if you see the test message your good to go. BTW, it's only 1080p/24, if your TV doesn't report via HDMI that it can do 1080p/24 it won't work. The only 1080p programming now is some PPV's on the PPV channels, some PPV DirecTV on Demand movies and there were a couple free MGM 1080p movies also on DoD, Futureworld was one of them.
There are some places that do install upgraded drives in the HR24's but that probably voids the warrenty with DirecTV since you've opened the box.
post #120 of 1949
Thank's for the clarification.
The source I use to buy 2 TB DTV stuff sells you the box upgraded (you own it) with their own 1 year warranty. I have nothing but good to say about them. Had an HDMI port fail, and they repaired / returned it in 72 hours.
They also sell 2 TB external "plug & Play" SATA port HD's, at least for my 21HR-Pros. Have no idea if external's are available for the HR-24.
  Back to Forum: HDTV Recorders
