According to this explanation of plasma sub-field drive, it would seem to be possible for plasma manufacturers to create displays that could eliminate 3:2 pulldown judder altogether. A 192hz display rate (96hz per eye per second) with the Panasonic (or Samsung) plasmas would seem within the realm of possibility for the first generation products. Is it harder than it sounds like it should be, and if so, why?
From the link:
"A Plasma panel display has near instantaneous response times on the order of 0.002 milliseconds. What this implies is that a plasma TV subpixel is only alight for a fraction of a second. Typically, most conventional Plasma TVs display video at 60fps (research has shown that the human eye cannot tell any significant difference in motion and smoothness of videos at higher frame rates). This implies that each frame has to be displayed for 1/60 or 0.017ms. However, the sub pixels of a plasma TV stay alight only for around 0.002ms when excited. Thus, to display a single frame for 1/60 seconds, the plasma panel excites the sub-pixels in pulses so as to keep all the pixels bright so that they can continuously display the desired frame.
Thus, for example, a 60Hz plasma panel can have 10 pulses per frame, to display the image. Effectively, the screen is being refreshed 60Hz times 10 pulses/frame which gives us a value of 600Hz. This is what Plasma manufacturers refer to as the Sub field drive refresh rate. If the Plasma panel performs 8 pulses per frame, it gives a sub field drive refresh rate of 480Hz. Now when the displayed frame has to be changed to the next frame, the ultra-fast response times of the Plasma TV sub pixels enables an almost instantaneous transition to the next frame."
From the link:
