Those of you who followed the original thread on the Samsung 7000 LED ghosting know that I was one of the first to supply specific details on the issue. I'm happy to say I have now completely removed ghosting and this is how it's done:
1. Update the TV's firmware.
2. When update is done, go into the picture menu, then the 3D menu, and turn auto 3D off.
3. In the same menu, adjust the 3D viewpoint from 0 to +5.
4. Start MvA.
5. Enjoy your movie with no ghosting!
I appears that the firmware update added 3D viewpoint as a new menu feature - I don't remember it being there before, and it's not in the manual.
The best place to see this new feature in action is in the opening asteroid belt scene, where I described how when you leave the asteroid belt and focus in on the planet that is about to explode, you can clearly see ghosting on the right side of the planet. Pause the movie and the ghosting is still evident. Pull up the 3D menu and adjust the 3D viewpoint. At the 0 setting the ghosting is still evident; at -5 it is worse. But moving from -5 to +5 you can actually see the ghosted image shift to the left and become smaller and smaller until it disappears.
The only reason I stumbled across this was I bought my new Pioneer 1.4 receiver and wanted to see if it had any affect on the ghosting. Kudos to Samsung for fixing this problem with a simple firmware update.
I'm so stoked that I can't wait for some other movies to come out!
My apologies if this was reported elsewhere - I haven't seen any mention of it.
4. Start MvA.
