AVS › AVS Forum › Display Devices › Rear Projection Units › Samsung HLT6187SAX/XAA Red Trouble
post #1 of 2
I'm new to posting here but have been reading the forum for a while. Thanks for all the great info. Here's my problem. I have a 6187SAX/XAA and it's having the following issues. For a few weeks I would turn the set on and have some random color as the prominent one for the picture. RED was popluar, green sometimes, vertical lines and odd colors other times. After I would cycle the set once or twice it would be fine for the duration.
As time went by it got worse. It would come on but no picture and cycle off and back on by itself. Sometimes to a perfect picture and sometimes not. Again I could cycle it until it got happy.
Now I am missing red entirely. I have downloaded the service manual and used to service older CRT type TV's so I'm familiar with electronic troubleshooting to a fair degree. I have had the LED engine out to check connections and look for cold solder but nothing obvious yet. I have been thinking of buying the RED LED after all I've read but I'm wondering if there is something else going on that could have been responsible for the strange behavior I noted above. I would have thought that if it were just the RED LED I would not have experienced that stuff. I though I saw mention of 15VDC to each LED but can't recall where.
Also it seems that the volume may have diminished a bit.
Any ideas from you smart folks?
Thanks so much!
post #2 of 2
I just joined this site today so I just saw your message. In the event that you still have the set, I may be of some help. I have been in the audio/video repair business for over 30 years and I had a VERY similar issue with this model. I was repairing it for a customer and all the while, Samsung kept feeding me the "try this" approach. After replacing everything in the set (digital pcb, led drive pcb, led power supply, main power supply)..it ended up being either the main signal pcb OR just the DVI cable. I woul try the DVI first because that will be cheapest.
  Back to Forum: Rear Projection Units
