My Samsung LN-T4661 (3yrs old) had been working fine x 3 yrs until 2 days ago, when it blacked out. When I tried to turn it on, it would cycle through clicking, with no picture. The symptom was exactly as shown below in the youtube videos i found.
youtube.com/watch?v=Mm51C_RDIZE
youtube.com/watch?v=BNHHrgX_6cs&feature=related
On the power board (BN44-00168B. vparts4less.com/images/Power%20Supply%20Main%20BN44-00168B.jpg ), there are 6 capacitors in the cold section. 3 are 1000uF 25V, and 3 are 1000uF and 10V. The three rated at 10V were fried. I replaced yesterday with 2 1000uF 35V and 1 1000uF 50V (there were the only ones I could find at Fry's and Radioshack, and as I understand it, you can replace with higher rated capacitors).
Awesomely enough, that fixed the problem of the clicking. THe TV now turns on, but the picture is dim. I have the contrast and brightness up 100% with backlight on 10 and it's still dim. I'm now considering the following:
1) I inadvertently fried one of the capacitors I installed. (I'm not an electrician and had a cheapo soldering iron that didnt get too hot).
2) The firmware needs to updated. I'm praying this might be the problem. I never had to update the firmware since purchase, so I'm skeptical this will work.
3) Somehow, the repair of the power board, made the inverter malfunction? not sure about this. I never opened or touched this part of the TV. Also, if it was malfunctioning, wouldn't the TV just not turn on?
HERE is what I'm planning:
1) I'm gonna buy some more capacitors and try to replace again. I've got nothing to lose here, because if it doesnt work, I;ll buy a new power board.
Should I use 1000uF and 10V as was initially on the board? Or higher voltage. What about a higher capacitance component? what would happen if i used 2200uF, will that deliver more power, and more light to the TV?
2) If 1 doesn't work, then Ill swap out the board.
I AM A TRUE NOOB when if comes to circuit boards and TVs in general, so PLEASE HELP with your insights and suggestions.
If you want help, you have to READ, COMPREHEND *AND* FOLLOW the answers you're getting...
