Here is a Post By Jeff Permanian on the JTR Forum site:
The mentioned June 12th (Saturday) initial public demo will be in my HT in California. A pair of Orbit Shifters will be replacing my dual Captivators and all interested parties are welcome to attend. I will be posting a Thread with details in the Area Home Theater Meets Section of the Forum.
Should be interesting ...
The Orbit Shifter LF is currently in development and should be available by mid June. The first are to be displayed in public June 12th.
100db 1w (103db 2.83V) outdoors, ground plane, 1 meter
25-150hz +/-3db outdoors, ground plane
30" tall, 22.5" wide, 45" deep (mouth 30" x 22.5" side)
160 lbs
Uses the same amplifier as the Duo, 4000 watts RMS and 7200 watts burst peak. "Low" mode will adjust the subwoofer for flat response down to 20hz.
Output Capablility: (calculated from 4000w, not 7200w peak)
133db average above 25hz, outdoors, ground plane, 1 meter
120db at 20hz, outdoors, ground plane, 1 meter
103db at 10hz, outdoors, ground plane, 1 meter
145db average above 25hz, eighth space (corner loaded), 1 meter
132db at 20hz, outdoors, eighth space (corner loaded), 1 meter
115db at 10hz, outdoors, eighth space (corner loaded), 1 meter
In room numbers will be even higher than the eighth space (corner loaded) calculations.
For best results from two Orbit Shifters, install them along a wall either facing corners of a room, facing each other or, one of each depending on room modes.
Retail - $3599
Direct - $3199
-5% - $3039 (+4)
-10% - $2879 (+8)
160 lbs
Retail - $3599
Direct - $3199
-5% - $3039 (+4)
-10% - $2879 (+8)
