AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Official JTR Orbit Shifter Subwoofer Thread
Official JTR Orbit Shifter Subwoofer Thread - Page 2
post #31 of 572
Originally Posted by bodhisafa View Post
How is this design capable of these enormous numbers if the amp in only puuting out half of the stated power numbers based on the limits of a circuit. Jeff calculated everything of the 4000Watt estimate but if the amp is limited to just half, then those numbers are not realistic, is this correct or am I missing something?
Without getting into what circuits can provide without being tripped, even if the amp can only deliver 2000w that's only 3db less than the stated numbers. So only 142db >25hz. Yeah that just won't do.
post #32 of 572
Originally Posted by Sphinx360 View Post
4000Wrms? But isn't the limit from my typical 120V 15A AC line about 1800Wrms based on a 100% efficient amp?
Can you produce an honest 4000W sine wave for 2 hrs off a single 20A, 120V home circuit? No. Do we ever do this in audio playback? Nope.
If you have the capability to deliver 4000W for a useful duration ranging from 15s to a few minutes, no audio signal you will want to listen to with peaks of 4000W will have an average power of more than 2000W, and more likely less than 500-700W. Circuit breakers are there largely to protect wires from overheating and to protect from fault (short to ground) conditions. They react on a much longer time average than peak audio signals. MANY audio enthusiasts operate systems with 6000W or more on a 20A circuit without popping breakers.
If you are using these in the interest of good sound quality you are generally more than safe if you figure circuit loading at 1/3rd-1/6th maximum audio power, with 1/4 being a good target. If you are running subwoofers very hard for dance use and regularly hitting limiters, clipping amps and running compressed signals, 1/2 maximum audio power is generally plenty safe.
The 4kW amplifier Jeff is using is the same amplifier I'm using in my Terraform XL and some other future products. I've been testing prototypes of the amp for more than 6 months. I see no problem with normal use of a pair of these 4kW amplifiers on a single 20A home circuit.
post #33 of 572
Gentlemen, thank you for the response(s) to my question regarding amp power and circuit limitation. It was just a question needing some clarification, not and attack on JTR, Iam an owner.
post #34 of 572
Actually it was a reasonable question that led to a good technical explanation (not mine ). A teaching moment if you will .
post #35 of 572
RMK! Will you be doing max SPL measurements? Please
post #36 of 572
With Jeff P. here I don't think I will have any choice in the matter .
Hopefully, he will get his "turn it up" jones satisfied before the Meet. Not everyone attending (myself included) likes 130db .
Reminds me, I need to warn the neighborhood .
post #37 of 572
So.... whats the news on this lately? Pictures?
post #38 of 572
I know what you mean, I have played 130 db's at my LP position and your ears pressurize so much that it feels that you are under water. It gets scary and I backed it off. Forget about high frequencies as that will cause damage.
post #39 of 572
The first prototype should be finished within the next couple weeks.
post #40 of 572
The problem with having that much audio horsepower is the temptation to use it.
Now that is some good news.
post #41 of 572
Will there be an option to use an external amp if we wanted to?
post #42 of 572
Orbit Shifter LF subwoofer uses a 68 lbs, 18-inch driver news from JTR forum!
post #43 of 572
Guys, let's start up a new thread once these hit the street per AVS rules.
post #44 of 572
The first Orbit Shifter pair has landed in California and setup starts tomorrow. I will post initial impressions and some pics then.
I'm hosting a GTG on Saturday and hope that some others will also comment on this unique commercial sub design. Did I mention they are LARGE?
post #45 of 572
Can't wait to read your feedback.
post #46 of 572
Too bad I am on the wrong coast... I would love to witness the official unleashing of the Orbit Shifters. As a precaution, you may want to notify your local seismology office of your plans...
Have fun! Take lots of pictures, and maybe a video.
post #47 of 572
Looking forward to it Rob!
post #48 of 572
OK here are some pics. We had a power cord issue (don't ask) and Jeff is just completing a 4hr round trip drive for a replacement. One OS is working and after running a quick Audyssey the results are very impressive . Much dialing in to do but so far so good.
With Grill
Big Mouth ()
Amp
That is all (for now)
post #49 of 572
very nice.... very nice indeed.
post #50 of 572
Looks great Rob. I'm eager to hear your impressions!
Chris
post #51 of 572
Stated simply, COOL.
post #52 of 572
Gah! You tease.
post #53 of 572
Eeesh! We have enough problems with scientists attempting to suck the Earth into a black hole with the Large Hadron Collider. Now you reckless sickos are going to unleash not one, but TWO Orbit Shifters for your evil weekend experiments?! I hope you are proud of yourselves, planet wreckers!
post #54 of 572
Sorry flat earther …
Jeff Meier (Accucal) spent 6 hours calibrating the projector and audio last night with Jeff P and I carefully observing the process. The result was a perfectly calibrated RS35 and a nice flat audio FR in the room. Not being a big fan of Audyssey, Jeff M used the manual EQ of my Integra SSP (DHC-80.1) and his very nice measuring gear to set the levels and EQ points for the system. Mr. Meier is very knowledgeable and a consummate professional who provides his customers with a nice bound copy with all of the settings and video calibration results at the end of the process.
On the audio side, I think he was a little surprised but the size and type of subwoofer that was dealing with last night. He see’s 2-300 systems per year and so is seldom surprised but the OS’s along with a few select others are breaking new ground (and drywall) .
We are planning to run an Audyssey calibration this morning just for comparison purposes.
Science marches on …
post #55 of 572
Great update. I agree with you on Jeff %100. Also, even though my system and room are small he also indicated that what ever I did, I did it the right way. He said that I should really not change a thing becasue it is my room that is the limiting factor. Even though my surrounds don't "match" he felt that it was not a distraction. He also felt that EQ, which I don't have, is the way to go. Glad that the calibration worked out for you. Now you can watch all your movies again for the first time.
post #56 of 572
Diggin the setup as always a very clean implementation. Are you still crossing the Triple 12s at 60hz or are you letting those Orbit Shifters flex a little more?
post #57 of 572
RMK - the subs look menacing! Congrats on the upgrade.
Do you have sound proofing for your ht? Is it a distraction for the rest of the house with the monster subs/spkrs?
post #58 of 572
Sorry flat earther
Hey, I like my Earth like I like my frequency response!
Now, can has more updates, pictures, body count, pls?
post #59 of 572
+1..... cmon already.
post #60 of 572
Jeff Meier (UMR at AVS) (jeff@accucalhd.com) spent 6 hours calibrating the projector and audio last night with Jeff P and I carefully observing the process.
Thanks for your calibration report. I've included it in the front projection (Post#1) lists that are linked at the bottom of my post.
