AVS › AVS Forum › HDTV › HDTV Technical › Coupon Eligible Converter Box (CECB) › Insignia DTV NS-DXA1-APT Not Turning On
post #1 of 7
I have an Insignia DTV NS-DXA1-APT that does not turn on. There is no light (red or blue) when the unit is plugged in.
I understand this is similar to the Zenith DTT901 model.
Does anyone know if there is a reset switch, diagnositcs I can run on the unit?
Thanks in advance!
post #2 of 7
If there is no power, a reset switch or any diags is pretty much out of the question.
You may want to look for a fuse that has failed. If there is not an external fuse socket, you may have to open the box. Just be sure the box is unplugged first.
post #3 of 7
the Insignia and Zenith 901 are the same, and there have been quite a few 901s that started malfunctioning and/or completely dying a few months after purchase (it happened to me), unfortunately your Insignia is one of them, I'm afraid.
post #4 of 7
The Zenith and Insignia CECBs have a "fusing resistor" as seen at the lower left in the first photo.
post #5 of 7
Is the fusing resistor in this picture: ZENITH DTT901 POWER CIRCUIT BOARD.jpg?
I would have to have a friend look at it who know what he/she is doing. I take it that this may have occured with other units.
Also, do you know if there are any schematic diagrams for this unit?
Thank you.
post #6 of 7
1. Yes, at the lower left. Notice the "Caution" text in the photo.
2. I don't have the schematics but they may have been posted back in 2008.
post #7 of 7
Thanks for the suggestions. My friend said that the unit does show power running through the unit, and doesn't believe it may be a problem on the power board.
He has not tested the fusing resistor specifically. Can the power board work / show power flow with a bad fusing resistor?
This thread is locked
