Well, it seems like I'll have to update the website to include 130 - inch CIH.
Mike-
I'm just north of LA. I'll be doing a couple of "beta" CIH screens w/masking systems next month. I can supply screen material (Pfifer 4500) but the concept is to have the customer supply their own screen material.
I know how to do 4-way masking, but I have not prototyped a screen yet.
There are some pics on the website now, and more will be added to the gallery as the they stream in from installers.
Re-designing the controller now, and it will be available in July with presets, and jog.
I can make various AR screens.
Can't comment on a Carada, since I haven't seen one. But I guess it would be like comparing a Cadillac to a Chevy. Both will get you there. Some folks wouldn't be caught dead driving a Chevy, while others are very happy with 'em. It depends on your budget.
Since I do all of my own design work, there is a cost savings. I use components that are reliable, yet cost-effective. For instance, I get +/- .062 inches of accuracy out of a six buck encoder, which is not bad. All I have to do is add firmware and stir.
Don
