Hi All,
Here is my setup before I get into my situation:
CPU: AMD Athlon II X2 240
MOBO: Asus M3N72-D
RAM: G.Skill 2x2GB DDR2
GPU: Sapphire 5670 (ATI CCC 10.4)
Display: Samsung LCD 4661
AVR: Denon 790
OS: Vista 32-bit
So as of now I have ATI 10.4 installed on my build without EDID Override and using the ATI HDMI Audio driver that comes installed with CCC. I am able to get bitstreaming audio using PDVD9 with any of the BD discs that I have. I would like to be able to play all of my ripped BD/HD-DVDs using MPC-HC + FFDShow. I have installed the latest versions of MPC-HC and FFDShow and have uninstalled any other codecs that were on my system. I followed the guide put up by dbone: http://www.mediasmartserver.net/2010...7-htpc-part-i/
However this guide relates to Win7 and I'm using Vista. The one big difference I see between this guide and my setup is that I can't seem to find the Microsoft DTV-DVD Audio Decoder to block it in MPC-HC. I am able to play some HD-DVD rips since I think these don't have HD audio tracks. When trying to play BD rips like Dark Knight or Star Trek or Quantum of Solace or Zombieland the video seems to be played back faster than normal and all I here is static for audio.
Anyone have any suggestions on what I can do to correct my setup? Thanks for your help.
MOBO: Asus M3N72-D
AVR: Denon 790
OS: Vista 32-bit
