AVS › AVS Forum › 3D Central › 3D Tech Talk › PS3 3D and Samsung 3D
PS3 3D and Samsung 3D - Page 3
post #61 of 63
Originally Posted by Oniichan View Post
hi,
to get World of Warcraft in 3D, you will need a PC with an NVIDIA Video card, go to Nvidias website and check it out. Nvidia will be releasing soon drivers for their 3D Vision for the new 3D tv's of today. But you will need a PC with an Nvidia card for computer games in 3D.
the PS3 has some games in 3D, i have them, Avatar being one. there are others and they are making more with 3D support. if you have a PS3 go to the Store web, games, you will see they have a 3D section to look over, they have demos too........
If you don't want to get an Nvidia card for your PC, you can also get an ATI/AMD card. Instead of having to use the proprietary Nvidia Vision Kit, you can use the same glasses and emitter that you would use for a 3D-TV. You will also need a 3d driver from tridef or iz3d, but they are available at half-price for ATI/AMD video card owners. The Tru3D guys probably have a whole kit available or something, they can at least steer you in the right direction. The downside with the Nvidia kit is not being able to just use it with the PS3 or a 3D Blu-ray player, so you end up having to buy two sets of glasses. Yeah, there's some hack where you have to leave the computer on with a video loop running, but who wants to be sucking down 400 watts to a computer when you're not even using it... I'd go the non-proprietary route.
post #62 of 63
Originally Posted by TRU3D007 View Post
Simply purchase the TRU3D 3D TV Adapter for Samsung DLP.
It will fully update HDMI port #3 into a plug-and-play HDMI 1.4 compliant input for all of your devices including the PS-3!
Or you can follow the directions from this thread, and spend the $300 you saved on some 3d movies. There is some risk, but so far no one has posted any failures/damage to TVs.
post #63 of 63
Wouldn't you only save $170 since you'd still have to buy the 3D-A1 for $99 and the powerstrip software for $30? Assuming of course that your time also has no value...
  Back to Forum: 3D Tech Talk
