I never seem to be able to strip and terminate RG6 properly. (eg. my connectors are very loose, fall off, etc)
I'm not sure if it's my tools but here's what I'm using:
IDEAL Coaxial Stripper, 3-Step
and
IDEAL Economy Compression Tool
I've read two methods for stripping the cable:
1) Remove outer jacket, outer braid, and outer foil. Fold inner braid down around jacket and leave inner foil in contact with dielectric.
2) Remove outer jacket, leave outer braid, and remove outer foil. Folder both outer and inner braid down around jacket and leave inner foil in contact with dielectric.
Which is correct? I've also heard of removing the inner foil and/or folding it against the jacket along with the braid.
Also, is my compression tool compatible with both RG-6 and RG-6 Quad?
Thanks so much...
and
Thanks so much...
