AVS › AVS Forum › Audio › Speakers › In Wall Speaker help for < $2500 budget
post #1 of 3
Anyone have any input for these in-wall/in-ceiling speakers?
3 Bowers & Wilkins CWM7.5 custom in-wall front channel speakers, 5" drivers
4 Bowers & Wilkins CCM664 custom in-ceiling effects channel speakers
If not these what is an alternative?
Room is 20 L x 12 W x 10 H. Not perfect square. In basement.
to be set up with the below:
Marantz SR6004 7.1 surround sound receiver
Also Triad BRONZE6 custom in-wall dual 10" subwoofer w/ amplifier? vs Bowers & Wilkins ASW610 compact 10" powered subwoofer?
post #2 of 3
Good in-wall speakers have an enclosure. I would only look at speakers designed with enclosures. Don't be fooled by speakers that offer back boxes as an option. Either a speaker is designed for open baffle or an enclosure, not both. I use RBH SI-760's in one room. They are very nice speakers, but may be out of your price range if you are trying to get seven speakers and a sub for $2,500. The 740 might work for you.
http://www.rbhsound.com/si740.shtml
There are several companies that make speakers with enclosures.
post #3 of 3
Narrowing it down to -
vs
Velodyne SC-600 subwoofer - possibly dual will cost same as above single
vs
Paradigm Seismic 10
vs
your suggestion
  Back to Forum: Speakers
