I have a rough plan for a subwoofer...and i am including it. This will go in my car and i want to change the dimensions to better fit a space. I need ti to be longer and more shallow...and the woofer and slot will be firing UP.
I included my rough changes in red....the 36" wide is a max...and the 8" or less height is a wish.
i just want to know if i can make the box fit...and i keep the port length the same...will i be OK?
slot port IDQ.pdf 62.2861328125k . file
