Originally Posted by
Quidsane
Haven't gone through this whole thread yet (working on that now) and don't know if this has been mentioned yet.
I posted about this on
camcorderinfo and I think it bears repeating here (if it hasn't already been discussed):
I have discovered something!
I've discovered that the VERY inexpensive Sony BDP-S270 can play the 1080p/60fps raw video from this camera when placed on a USB stick.
Player displays "
1080/60p" while playing.
After the discovery, I tested three file extensions (.mts, .m2ts, .mkv) and they all worked!
The .mts file (00000.mts) was dragged right of the SD card straight out of the camera (which the Sony detected as "M2TS").
The .m2ts file (20100821_212439.m2ts) was imported off of the internal flash drive with HD Writer (no conversion). The Sony detected this as "M2TS" as well.
The .mkv file (20100821_215351.mkv) is actually an .m2ts file with the extension changed. This was detected as "MKV". Then I BURNED THE FILES TO DISC and
YES! The future is here! Everything played flawlessly! Some screenshots here
(notice the video bitrate at the bottom left):
Tried this same experiment on my Oppo BDP-83 and it will not recognize .mts or .m2ts as file extensions.
Oppo only "sees" .mkv. Alas, the .mkv was too much for the Oppo it would "stutter-play" the file.
Too annoying to watch for more than a few seconds.
But that is all moot because now we have this Sony BDP-S270.
This player is 100 bucks (give or take) at freaking Wal-mart!
This is the lower end of the Sony spectrum so I would expect that the higher end models (BDP-S370, etc.) can play these files as well.
YAY!
I only changed file extensions for experimentation purposes.
If you copy an .mts file right off the SD card straight out of the camera, the Sony BDP-S270 will detect it as "M2TS".
This works on USB flash drive and on standard single-layer DVD5 (4.37gb). I have not tried with DVD9 or BR Disc.
I used Nero to burn .mts files as DATA using "DVD-ROM (UDF)" as compilation type.
I am still completely amazed about the fact that the Sony can handle these files
My sincere apologies if this has already been discovered/discussed.
