Originally Posted by dakotase
Use txmuxer to stitch them together. http://www.smlabs.net/tsmuxer_en.html
Greetings dakotase.
There was a post by hazydave on the topic of joining clips, but he did not reply when asked to clarify. Perhaps you could answer on his behalf.
Many thanks and best regards.
Originally Posted by mariner888
Greetings Dave.
I noticed when using HDWriter the playback is seamless.
Just to clarify, are you saying there will be glitches if different segments are joined together using tsMuxeR?
If so, will the dos command copy/b work?
Originally Posted by hazydave
Ken's program looks ok.
The Panasonics don't drop a single bit when splitting the file. However, they also don't break the file at logical boundaries (like, at a GOP boundary), they break them at the 4GB boundary. So if you drop 00001.MTS and 00002.MTS onto a timeline, there's going to be some mess there at the boundary. What I'm doing is a dumb catenation, which is exactly what you want to fix the issue. I believe that's what Ken's program does, too.
There's no need to analyze the file contents. A program like TSMuxer, or other video-aware program, is not the right answer here, unless it's specifically designed to detect this situation.
Greetings Dave.
hehehe
The 720@59.94 though on fast moving objects is awesome.
