AVS › AVS Forum › HDTV › HDTV Technical › what is a "Tv panel"?
post #1 of 9
im having to get a panel replacement on my ln46c670..i was just wondering what exactly is the "panel"? what part is that and what does it do?..
post #2 of 9
its the screen.
post #3 of 9
will that help with dead/stuck pixels and clouding/flashlighting?..
post #4 of 9
Should.
post #5 of 9
one more question for you guys..i have these lines at the top of the screen of my c670..its pretty annoying..i turned the sharpness down to zero and that helped a little but not completely..these 2 are with it set to 50 and this one is with it set to zero..and it isnt just the blu-ray player/lord of the rings..it does it with sattelite as well, and hd channels..and the picture is darker across the top of whatever i am watching too, like a dark border or something..especially with full screen content
post #6 of 9
one more question for you guys..i have these lines at the top of the screen of my c670..its pretty annoying..i turned the sharpness down to zero and that helped a little but not completely..these 2 are with it set to 50 and it isnt just the blu-ray player/lord of the rings..it does it with sattelite as well, and hd channels..and the picture is darker across the top of whatever i am watching too, like a dark border or something..especially with full screen content
Dude can you post smaller pics? I'm having to scroll sideways even at 1650 wide and I usually have it set at 1440. Try keeping them under 1200 pixels wide please. Thanks.
post #7 of 9
got panel replacement this morning...already found 1 green stuck pixel and 1 blue stuck pixel on it..also looks to have flashlighting in bottom right corner that is visible even during the day...*sigh*..time to just try to ignore it and get over it until i can afford something else next year maybe..
post #8 of 9
Download Irfanview for free, you can re-size your pics with it to a more reasonable size...
post #9 of 9
I wouldn't ignore it. I would call whoever replaced it for you and tell them to come back and fix it properly.
  Back to Forum: HDTV Technical
