AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › The best pair of subs you would you buy (under $10K)?
The best pair of subs you would you buy (under $10K)? - Page 8
post #211 of 376
thebland,
I highly suggest a sub from JTR, Seaton, or Danley, whether custom or not. They were all part of the company that built your B-deaps(I think) so you know what to expect. Maybe Danley can build you a custom horn that will due 5-25hz and integrate into the B-deaps? I have run sine waves with my dual DTS-10's up to 120 db's at 10 hz(where my meter starts falling off) with no problems. I have no doubt that it extends a little lower. It just seems a shame to waist all the great midbass from any of the subs recommended. Go custom, 5-25hz.
post #212 of 376
The sign above the door says....
DO NOT FEED THE TROLLS
So what are you saying, the OP is a known troll I'm not aware of or........? Regardless, it never hurts to ask, he may have/willing to share more accurate info on the driver.
GM
post #213 of 376
GM
Sorry if there is confusion here. The OP is not a troll whatsoever... Ntrain is the troll, you replied to him and Im saying its worthless for you to try and discuss anything with him. He is posting nothing worthy of a response.
post #214 of 376
thebland,
Best post in this thread!!
post #215 of 376
OK, thanks, good to know. I have so little time anymore to follow threads that I usually am just responding to what's in front of me that's of any interest when I click on it.
GM
post #216 of 376
I like both buttkickers and the pressure felt from the low frequency subs.
Are you using the Buttkicker LFE and if so what amp and crossover?
post #217 of 376
Originally Posted by mktheater View Post
thebland,
i highly suggest a sub from jtr, seaton, or danley, whether custom or not. They were all part of the company that built your b-deaps(i think) so you know what to expect. Maybe danley can build you a custom horn that will due 5-25hz and integrate into the b-deaps? I have run sine waves with my dual dts-10's up to 120 db's at 10 hz(where my meter starts falling off) with no problems. I have no doubt that it extends a little lower. It just seems a shame to waist all the great midbass from any of the subs recommended. Go custom, 5-25hz.
+1
post #218 of 376
thebland,
With all due respect, I think there have been several references by the OP to Seaton, Danley, and probably Jeff Permanian. It is clear to me that Jeff (the Bland) is in touch with those guys and will almost certainly end up with something from one of those guys. After all, these are the same people who put his Bdeaps where they are and calibrated them.
TheBland clearly is not going to settle for something less than stellar. What he has now will eclipse 90% of what Forum members have. Thebland also is not about to rush into anything. He has both the time and money to wait till the right design emerges, and to make sure it is what he is looking for. No revolving door here.
It is ironic that the one existing product that would just nail the 3-25 Hz range is the Thigpen Rotary TRW-17. If I am not mistaken theBland has heard the Thigpen but his room is not a good match. Also, even he might hesitate at the expected installed cost of the Thigpen at $20,000 +.
So, a conventional design it will be.
In any case, with Danley, Seaton, and Jeff Permanian working with thebland behind the scenes, we should see something in the next 6 months.
post #219 of 376
I use buttkickers. Buttkicker is a power hungry gadget. You need an amplifier that provide up to 1,000 watts at 4 ohms. Your best bet is to get Buttkicker's own amp.
post #220 of 376
Originally Posted by thebland View Post
The theater is on a slab. The 2nd and third rows are wood constructed tiers.
Risers, (wood constructed tiers), can have the same impact on tactile response as suspended floors, especially if the stringers, (joists) are shorter than the frame, so they don't rest on the concrete floor. Risers will have a resonance frequency and they will vibrate at the RF the same as a suspended floor would. The key difference is they have lower mass and therefore a higher resonance frequency.
The BDEAPs do not shake the floor but vibrate the chairs a bit. The Buttkickers so a superb job of 'shaking' at my crossover level.
What crossover level is that? I have my Crowsons LPF'd at 40 Hz. They have response down to 5 Hz. This is the only bandwidth I find to coincide with a "natural" shaking effect.
Craig
post #221 of 376
It is ironic that the one existing product that would just nail the 5-25 Hz range is the Thigpen Rotary TRW-17. If I am not mistaken theBland has heard the Thigpen but his room is not a good match. Also, even he might hesitate at the expected installed cost of the Thigpen at $20,000 +.
Why then was this opened up for discussion?
post #222 of 376
I don't speak for Jeff, but it seems to me that he wants to make sure there is nothing out there he hasn't considered. Also, this way the really serious bass heads get their chance to opine on the entire upgrade, and Jeff gets to sift through all the suggestions and that helps focus on what general approach he is most attracted to.
post #223 of 376
I'm not speaking for Jeff but, in reading his posts, it is important to him that he can incorporate whatever designs he chooses into his existing space without significant modification.
The TRW (Thigpen Rotary Woofer) requires shaping/designing the space around it as it has very specific requirements (which is why the design process gets incorporated into the final price and 1 reason it is so expensive)...
Having heard one before (in Chicago) it is amazing....but it has to be one of the rare instances in which you choose your equipment before one can commence with designing the space.
I don't think you can go wrong with Jeff, Mark, or Tom. Each has strengths and weaknesses that can be appropriately utilized in your space.
post #224 of 376
Excuse my ignorance, but what are the advantages to using a horn design like a SPL-BDEAP32 as opposed to something that is smaller, goes lower, and has a high sensitivity handling?
post #225 of 376
Not if you don't have any fire insurance.
http://www.avsforum.com/avs-vb/showp...58&postcount=1
Use with caution.
post #226 of 376
Yes butkicker LFE, split off from my Subout on my AVR. The amp is the buttkicker amp which is very simple and has Low pass filter settings on it. Its generally set around 25Hz and turned down or it will shake all the time for even midbass content which I do not want. The amp is right behind my seats so I can adjust when I want.
post #227 of 376
Originally Posted by Tom Danley View Post
Hi Bosso
Since you seem to have chosen me as your DTS-10 measurements whipping boy, let's clarify a few things, shall we?
First, your hiding behind what the pro sound industry does regarding measurements is not only a weak argument, it's irrelevant to the discussion.
Bosso from my perspective, by being the most outspoken critic, of a technology you weren't familiar with and never heard, you painted the picture or at least composed it.
Also, I am pretty sure if the average person looked at the gallery of some of the installations using our products, you will see that they are mostly all larger Pro-sound / commercial sound installations, the reason is that IS in fact the industry we are in.
I disagree that is irrelevant to what we do, what spec's are required, but actually focused on it.
Most DIY products have been measured, tweaked, nit-picked, discussed, debated and argued from every conceivable angle. Wiggins, Haskins, Kyle, Ding, Beltran, Kuypers, et al, have engaged in these discussions with DIYers, representing their company's amps, drivers and theories.
I know Carlos from ages ago and Dan slightly, but weren't they trying to build a business to sell products in the home ?
My posting on the DTS-10 DIY thread occasionally was what then, not discussing it?
Keep in mind, this was not a full fledged company project, this was MY IDEA of something fun not a core business move, or even something some at the shop knew about initially. I had to press to get this to happen.
I like to build things, I have explained that, that is how I got in the business, that's how I worked with Mark and Jeff back at Servodrive, they loved to build speakers too, also fully addicted to sound, fellow coneheads (but not from Remulac).
Far from being the exception, every single and multiple driver sub from 10" to 21" in a sealed, IB, ported, bandpass and passive radiator alignments has either been measured or performance has been fairly expertly extrapolated countless times by Nousaine, Mullen, Craig, Rissanen, CJWhitehouse and many other enthusiasts with capable systems and more than adequate knowledge.
Well I know who Tom Nousain is, have met him, the rest I don't , I presume they would be writers / reviewers for home gear or something.
I guess I am not clear on your point though, are you saying the other manufacturers normally provide CEA2010 data, or, that when products are being promoted and sent for review, that these folks measure them?
At some point we will send some home products in for review but we haven't finished any yet.
In the case of the DTS-10 "DIY" project, no T/S parameters for the driver are provided, no sanctioned measurements, no maximum output @ 1M, no motor topology details... pretty much no nothing but a quasi-anechoic frequency response and amplifier rating recommendation.
Lighten up Francis says sgt Hulka.
This was my idea, it was supposed to be a just for fun project, not something we were marketing or building a business on.
Why do you think we ran no print ads, didn't promote it like our regular products , why some of the folks answering the phone didn't know about it, getting the picture? IT WAS FOR FUN.
If I can, I am going to do another limited for fun project, maybe more complicated as this one went well. Like this one, it will be open to the most experimental mindset, like this, the people who go for it will know what it does and I don't see anyone complaining they were ripped off with the DTS-10 do you?.
If you have a problem with that approach again, don't buy one, it's not for everyone, it wasn't supposed to be.. That probably sounds like weird approach but hey, there we are.
The response to my inquiries, which were based on Ricci's prog sweeps, which at least provided a tad of reference vs his XXX sealed and ported sweeps as well as MH's apparently botched attempt at 2M outdoors test, were met with an avalanche of insulting remarks, capped by your own admonition that I should simply read other's subjective comments and leave it at that.
Picture this if you can, no one was willing to go back and take more data just for you. You did leave a bad taste, you probably knew that, so your insinuations had something to do with that reluctance, that and being winter /rainy..
What is humorous is that you fully accept and let pass all of the "you will not find sub(s) that will outperform them in output, quality, and extension", "have been numerous comparisons with..." "already know it's on a par with XXX, LMS..." completely unsubstantiated claims made in this thread and many other places, but you chose to post regarding a reference to your own published ground plane measurements, singling me out as the patron of the failed exercise.
You can probably understand that my concern is much less about people that say good things as bad, or worse incorrect things, like posting the CEA2010 result that was in question without the qualifier that went with them..
Please allow me to let Danley Sound Labs off the hook. I could not care less what the DTS-10 CEA 2010 numbers may be. Do not put yourselves through the expense and trouble because I won't care in the least what the results will be.
Bosso, you overestimate your importance in the big picture and as you infer, I know nothing, not measurements, not impressions could change your opinion, but as before, when time permits we will do them again as they do appear to be a useful measure.
There was just no pressure to do so, especially while it was winter and there were / are regular products to work on.
Meanwhile, it's time to put a new deck belt on the lawn tractor and then cut the yard hay.
Best,
Tom Danley
Very well put Tom. I for one do not know much about REW, SWEEPS or any other technical jargon. What I do know is that in my New Home Theater I have had many subs and multiple subs who's price would equal 3 of these kits and they never gave me the impact and feel as this Dts Project done. I have dual DTS-10'S and really wanted to add a 3rd just so I could blow the walls down If I wanted.
Please keep up the good work and make us another DIY project. PS. Ill mow the lawn for another chance at the dts-10 kit for the sell price.
post #228 of 376
Yeah, so true. What Bosso and the others are not posting that all these ALTERNATIVES cost 3 to 4 times what the DTS-10 design was offered to us for and Bosso (and others) think everyone should have 40 amp circuits in their rooms and 5000Watts of power on tap. That is so 90s if you ask me!! We have evolved! We should be wanting > 95dB sensitivity at 1W. Anything less is going backwards.
All I have to say is if you can not get the same performance for the same $$$ then maybe you should go back to the drawing board before you argue about it online.
Here is to hoping Tom Danley creates a new "FUN" project that will make Jeff very happy and offer us DIYer once again an opportunity to buy something NO ONE ELSE ever offers.
post #229 of 376
I agree... Kudos to Tom and the the folks at Danley for such a great kit and limited time offer. I'm just sad that I couldn't make it work in my space.
I will be watching with great interest for the next Danley project. Hopefully it's a tiny bit smaller.
post #230 of 376
I like Tom's DTS-10... I mean, what's not to like? IT is a powerhouse at ULF and that is what I am after... and for the price ($3K), I think it is a bargain.
That said, it is so big, I just don't think I can figure out a placement that doesn't hurt the esthetics of the room or if stood upright in the front corners in my room, adds a primary reflection. I could make them work if I had to, but I am still scouting all options.
Mark has solutions for ULF, too. Certainly the Terraform XL. I have talked to Mark and the issue is getting them in (or out). Mark, has the ability to do custom stuff which few can do. Plus, Mark is a known quantity to me as I have known him for many years.. well before he became the well respected, independent sub designer / manufacturer he is now.
The problem is, I'm going to need a big box for ULF. I know others are developing high power, small boxes with supposedly big ULF, but I am not going to beta test something. I have to have a company that has tested and stands behind what they sell. I have been thinking on this for a couple of years... particularly after spending a day at Art's (4 submersives )and Itai's (2 Terraforms). I could see (feel) how my BDEAPs were eclipsed in the ULF. I wasn't satisfied with my own, still very good, bass response after leaving those meets. Moreover, I wasn't just going to throw something in. It has to fit the room and give me ULF improved over the aforementioned systems. Since nothing can beat my BDEAPS over 40 Hz, I will leave them for sure.
THe Danleys and Terra XLs are about tops of where I want to spend, but I feel like I am keying in on a solution... and I'd like it completed before the summer's end.
post #231 of 376
Contrary to what many are saying the DTS-10 is not exactly a ULF monster. Once you get below the passband your harmonic distortion goes over 100% because the higher order distortion get the gain of the horn and the fundamental does not allowing the harmonic to be louder than the fundamental. There are some measurements in the DTS thread showing this. It's certainly an impressive subwoofer across the targeted operating range offering high efficiency, but I'm not sure getting one (or more) for ULF output is the right move for you.
post #232 of 376
If you have the ability to do this: http://www.avsforum.com/avs-vb/showt...5#post18052585
then you don't have to worry about the size of the box.
post #233 of 376
Not a ULF monster? I would call flat down to 10Hz pretty low. Am I missing something?
post #234 of 376
Yes, at first, the DTS-10 also impressed me as an awfully big box...probably because it actually is.
However, the more I thought about it the less problematic the issue of size became. For me, the issue distilled to this: The physical footprint of a DTS-10 is 16" deep by either 44" or 60" high (depending on which of those longer dimensions you place on the floor). In short, the 16" dimension makes this unit about the size of a bookcase against a wall. Kind of a heavy bookcase, I know, but it produces way more prodigious bass than any bookcase I've ever owned.
Anyway, the sub turns out to have a much slimmer profile than I at first imagined. It's 16' depth seems pretty unusual in a sub---I could have really used that small dimension when trying to locate several boxed subs I've used over the years in my theater. In a number of locations, I'm able to minimize the physical presence of the DTS-10 relatively easily in my room. As a matter of fact, in one position, it completely disappears. I was lucky in that one side wall happened to have a recessed area (84" wide, 96" high, 18" deep), and the whole wall is covered by curtains. So, pre-installation photos and after-installation photos of that location look exactly the same.
Then, there is the possibility of utilizing multiple units either beneath risers or AS risers...
Good luck in your decision.
Tom
post #235 of 376
Please point us to a ULF monster (with measurements, no subjectivity) from a commercial company that bests the DTS-10, one vs one below 40Hz in the intended price range, 2 subs for 10k$. The OP is not interested in DIY.
Just wondering, have you heard the DTS-10?
post #236 of 376
I wonder what he thinks an ULF monster is? It is tuned to 11-12 hz. It will get under that in a room(gain). Every sub has the distortion rise fast in the ULF area and multiples are needed to keep it down. The OP only wants 2.
post #237 of 376
I believe he is refering to frequencies well below 12Hz. THD will get all the benefits of the DTS-10 tapped horn, while the (already low output) fundamental will get none of that. So ideally you would feed the DTS-10 (only) with what it was made for (10Hz and up).
post #238 of 376
Penn,
This is a silly post.
Bosso
post #239 of 376
This is the problem, The only subs that go low enough or below 10hz are sealed subs with room gain and maybe EQ. Now, he only could have 2 so what 2 sealed subs that we know of that will have the output and dynamics to keep up with his B-deaps? They don't exist. We have submersives but 2 won't do it. The only thing I can think of is DIY which is also out.
post #240 of 376
THIS is the best post in the thread.
The B-DEAPS are the wrong hardware for the job...period.
Fixing that while retaining the B-DEAPS involves use of space and aesthetics, neither of which is down the alley of the 3 names suggested for the job.
Space and aesthetics, contrary to the few here who don't mind plywood coffins in their spaces, are a top priority for 90% of consumers.
Bosso
Bosso
