I have an Epson PowerLite 1080UB projector, which has been working well for me for a year and a half.
Recently, the bulb (2nd or 3rd one since projector new) started getting dim, and finally so dim there wasn't a picture to see. I replaced the bulb.
Brightness is back to normal.
But somehow I picked up a new problem that I can't believe is the bulb.
The picture has somewhat different color on the top half from the bottom half!
The dividing line is *exactly* dead center, as can be seen if I push the "alignment" button on the remote, or display a test pattern.
The bottom half has stronger reds and yellows, and somewhat on greens, but is almost the same on blues. Grey patterns have a different tint to them top vs bottom.
It seems like it's a problem with the color processing in the projector, or perhaps a loose wire somewhere. But that's a guess. Any idea what this might be? Or anything worth trying to fix it?
Changing color mode doesn't fix things (although the problem is most noticable on "dynamic" and least noticable on "Theater black 2").
I've done a full reset on the projector (settings and bulb hours both).
