AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The better of these amps?
post #1 of 6
Hi Guys,
I just picked up a Denon AVR-4800. I have JBL ND310 speakers. The guy also has two amps for sale. which one is the better of the two
Adcom GFA-2535
0r
Belles 150a
I'll be running four speakers and one sub from eigther of these amps. The question is which one is better?
Thanks for any info
post #2 of 6
Originally Posted by ducktailjiver View Post
Hi Guys,
Adcom GFA-2535
0r
Belles 150a
Thanks for any info
Review of the Belles 150a.
http://www.soundstage.com/revequip/b..._reference.htm
post #3 of 6
Hi Guys,
Adcom GFA-2535
0r
Belles 150a
Thanks for any info
Try Audioasylum.com. It is an audiophile forum. You will have better luck there.
I do not know the Belles but I have heard the Adcom. It is a good quality amp. The best way to determine would be to listen to both of them inserted in the same setup and trust you ears. Look for dynamics, transparency and musicality.
all the best,
Michael
post #4 of 6
Hi Guys,
Adcom GFA-2535
0r
Belles 150a
Thanks for any info
If both have the specs to drive your JBL ND310 then the one that cost you less money is the better choice!
I hope you are looking for used because I wouldnt spend a ton on amps when you really didnt spend a lot of speakers. Its not the right appoarch to getting the best SQ.
post #5 of 6
Michael
You mean AVS has no audio knowledge and only nutcase audiophiles would know?
post #6 of 6
+1
Before you buy an amp, try using just the 4800 as it likely is more than sufficient with those speakers. Use the money you save to upgrade to better quality speakers instead.
