AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Looking for a receiver that sounds like UMC-1 but works like my Onkyo 705
post #1 of 24
Several things in my system have been replaced over the last 4 years or so but for the most part, my receiver has stayed the same. I have been fairly pleased with my Onkyo 705 until I got interested in separates and decided to try Emotiva amps. Up until about a month ago I was using the 705 as a pre/pro along with an Emotiva XPA-3 and XPA-5 for amplification. The difference in adding these two pieces was huge and I would never go back to just a standalone receiver. Being impressed with the Emotiva line I decided to give the UMC-1 a try. Even with all of it's bugs I was immediately impressed, even amazed at the sound quality from it. I was hearing things from my surrounds that I never heard with the Onkyo. My usage is 95% home theater and the UMC-1 sounds so much more dynamic and detailed than my Onkyo and I'm now afraid to try anything else in fear of being disappointed in the sound. However, one very important shortcoming of the UMC-1 in my setup is it's lack of a true "passthrough" mode. I have confirmed that it is in fact doing a colorspace conversion and some video processing that I would prefer my DVDO scaler and Oppo Blu Ray player handle. Having said all of this, I'm now curious if there is something that would give me UMC-1 like audio but the features and true video passthrough of a more mainstream AVR? Regarding budget I would like to stay in the $800-$1000 range if possible. Things that are important to me whether it be a processor or AVR would be as follows:
-True video passthrough, I don't need the AVR or processor to do anything to the video.
-Onscreen GUI over HDMI where I can still see the movie while making adjustments (something I have come to enjoy in the UMC-1).
-Preouts for connection to my external amps.
-At least 4 HDMI inputs.
-Easy firmware updates, preferably via Ethernet connection.
-Processing of all the high def audio formats via bitstream from the Oppo player.
I think that is about it.
post #2 of 24
Why not add an HDMI splitter before the UMC and run the other cable directly to the display? This may cause lip sync problems - or not. Best to test it. You will retain HD audio capability and get unmolested video to the display.
post #3 of 24
I'm intrigued by what you propose here but can't seem to wrap my brain around it right now.
post #4 of 24
How many hdmi sources do you have and what model dvdo scaler dropzone ? If enough inputs ; all your video input sources go to the scaler and its hdmi output goes to a 1 in 2 out splitter ;one output to the display the other to the umc1 . This is the most economical way and solves the colour conversion problem
Or if the abt scaler doesnt have enough inputs a dvdo edge or duo will feed hdmi audio separately to the umc1 though that is more expensive than a splitter
post #5 of 24
what kind of speakers are you using?
post #6 of 24
Boy I wish I was in that room. I would do spectral analysis of each to really find out if I suffer from buyers placebo induced exagerations. There is no other scientifical logic for the UMC-1 to bring more detail to your surrounds so Im definitely intrigued but this amazing discovery especially if auto EQing has been done.
post #7 of 24
Drop,
The offer to come over and check out the 40.1 stands. It basically has everything you want except for the GUI overlay AND ability to watch the movie (that is a new feature for the '10 Onkyo line).
I would bring the UMC and the DVDO for the test.
post #8 of 24
Ah, I understand now. I have 4 sources right now and my scaler is a VP50. I think it has at least 4 inputs on it maybe more. I was trying to avoid adding another link in the video chain, especially something like a switch or splitter which can be questionable quality unless you go crazy money. This is still a consideration though so I may give it a try just to see what happens.
post #9 of 24
I'm using Ascend Acoustics CBM-170SE for front and left, CMT-340SE for center and (4) HTM-200SE for surrounds. My subwoofer is an eD A2-300.
And I wish you were here to help me do all of that! I don't have measuring equipment or the knowledge to use it either. I have an SPL meter and that's about as advanced as I got with my setup, 75db level matched the speakers. The 705 I used the Audyssey setup measuring 8 listening positions. I usually ended up going back to the manual adjustments because it didn't sound lively enough to me with the Audyssey engaged. For the UMC-1 I ran Emo-Q once and then manually tamed some of the sharp increases in the trims. Corrected the crossovers to what I was used to (80hz and 90hz) and changed the subwoofer distance to the actual measurement.
Originally Posted by D_Strasse View Post
Drop,
Yeah, I really need to do that. Of course I'm not sure how much hearing the 40.1 in your room with your speakers would tell me about how it would work in my setup. The DVDO is a pain to setup and if it wasn't for my wanting 72hz refresh rate for my projector I probably wouldn't have it at all. I need to find out when the wife will be away so I can come over and pick your brain.
post #10 of 24
Yeah, you would need to rip your UMC out of your system and bring it to my place so we could swap them back and forth.
I have an SPL meter but many here would say that isn't enough for level setting.
post #11 of 24
I'm patiently awaiting a reply from penngray because I know it's coming...
post #12 of 24
How else would you set levels? Scope on the outputs with a test tone?
post #13 of 24
In order to be able to "compare" equipment versus simply setting it up, yes, I "think" that is what some would say would be needed.
Edit: And I think rather than a scope, a multi-meter/volt meter would suffice.
post #14 of 24
Perhaps a true RMS meter would suffice.
post #15 of 24
Well, so far the most interesting idea is for me to try a splitter.
post #16 of 24
While I appreciate the fact that nobody has flatly said that my UMC-1 is junk and have instead suggested ways to make what I have work, I would also like to hear some suggestions regarding a total replacement. As stated before I really have no recent experience with anything other than my Onkyo 705 and the UMC-1. I don't mind buying a less expensive AVR that will be strictly passthrough for video and just used as a pre/pro for audio. The sound and tweakability of the sound is what I'm interested in.
post #17 of 24
Should have left well enough alone. V6 Beta 2 and I now have problems that didn't exist before. I'm about to say "to hell with this" and just buy a $400-$500 receiver to use as a pre/pro, sell the UMC-1 and Onkyo and use the proceeds to buy a new sub.
post #18 of 24
Then if you want to be able to tweak those settings maybe you need the give the Yamaha 665/765 a look. These should fit your budget and YPAO does allow tweaking.
post #19 of 24
Well, now that you've broached the issue, I'd suggest you consider the latest offerings from Onkyo (or Integra). I was waiting for the Parasound C3 but, when that project was cancelled, began to look at the UMC-1. The UMC-1 is out of the question for me now, given the endless string of problems it is experiencing & Emo's botched attempts at a response. At this point, I'm thinking again about the Onkyo/Integra pre/pro.
post #20 of 24
we figured you already knew that...
if i had to guess, there will be several 40.1's and 80.1's available when they release the .2 models... i'd also guess that supply will outstrip demand for them, so they probably will be available for pretty good prices...
ymmv...
post #21 of 24
I can't figure out why you are running your video through the UMC-1 (or any pre/pro) if you have a good digital processor that presumably does video switching as well? Which DVDO do you have, and does it have two HDMI outs so you can send one to the UMC-1? If so, I would do that and forget about running video through the Emotiva. If not, trade the DVDO in for a upgrade model that does that.
post #22 of 24
I know Onkyo has some nice new receivers but if they sound anything like my 705 (which was fine before I heard the UMC-1) then I would rather try something else. I don't know if that means Denon, Yamaha, Marantz, I have no clue because I have never heard any of these.
ymmv...
A 40.1 might be a possibility and I have read some good things about those as well as several forum members here owning them. I have an opportunity to hear one locally if DStrasse and I can work out a time. Life gets in the way of HT sometimes.
I guess I just got used to having an AVR do the switching and being able to name inputs, etc. I have the VP50 which is now a "legacy" product and not eligible for an upgrade path. So, the VP50 Duo makes the most sense for me with 2 HDMI outputs, v1.3 HDMI, lots of inputs, etc. My VP50 only has one output. Honestly, I probably wouldn't have a scaler/processor at all if I didn't have a CRT projector. I need the VP50 for 72hz output and the processing it does. I would buy an EDGE but it won't do 72hz.
post #23 of 24
Actually, it looks like they ARE doing upgrades from the VP50 right now. If I read the site correctly I could get a DUO for $299 after the trade in credit! I may just have to do that regardless of what I end up with for a pre/pro or receiver. I could have sworn I just checked this a few weeks ago and it wasn't an option. It does say "for a limited time" so it must be a fairly new offer. Thanks for mentioning this or I may not have checked the site again and missed out!
post #24 of 24
The Marantz AV8003's are nice & due for a replacement soon (so there should be some good deals on the second-hand market) but I'd also give the Integra 80.1 (or the Onkyo Pro equivalent) a listen. I'm not sure what your old amp sounds like but you might be pleasantly surprised.
