Originally Posted by EnterTheHaggis
I just bought the HT-SS370, great HT for the price. I also have a Wii connected by component cables. Unfortunately the A/V are too short to split them from my Samsung HDTV and the receiver, they're too far apart.
Two questions:
-If I'm using a component cable would that be considered a digital signal and therefore would an optical cable output the sound from the TV through the Sony reciever?
-I know you said RCA can be split, but can you split the component cables A/V to TV/reciever ?
I'm curious to know if he got his to work splitting the RCA.
thanks.
Two questions:
thanks.
Hi EnterTheHaggis, first off just to make sure we're on the same page. Component A/V cables has green, blue, red for video and red & white for audio. Composite A/V cables has yellow for video and red & white for audio. And both of these are analog A/V cables and not digital.
Depending on your Tv you have a few options of connections. But as samsurd2 mention SS370 does not have video Input, only audio Input (which you may know this already)
Options depending on your Tv, so read the Tv manual:
1. connect Wii (video and audio) to Tv, then connect a optical cable from "Digital Audio Out" or RCA cables (red & white) to SS370. Go into Tv audio menu and set Tv speaker to OFF or audio out to Surround or Home Theater". If this option does not work then use option 3.
2. connect Wii video to Tv, audio (red & white) using 2 RCA Coupler (plus extra RCA audio cables) to SS370 "AUDIO IN - TV" or "AUDIO IN - SA-CD/CD. This would only allow Wii audio from SS370 speakers and no audio from Tv speaker.
3. connect Wii video to Tv, split the audio (red & white) using 2 RCA splitter adaptor (plus extra RCA audio cables) and run one set to Tv and the other to SS370. This way it can have audio from Tv speakers or from SS370 speakers when you wnat it.
I had some weird settings going on with the sound field. Tested and works now. The fact remains that the center channel speaker that comes with this unit is a pathetic excuse for a speaker.
