AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › TC-P50G25 image retention
post #1 of 11
thinking of buying the panny TC-P50G25... but i often play games, or just let my mac mini play pandora/itunes/etc onscreen.
is this something is should be worried about? is the whole image retention still an issue?
also, if i put my mac mini at full 1080, will this tv shave pixels off the top/bottom/sides?
thanks!
post #2 of 11
IR shouldn't be an issue since it's temporary and can easily be fixed by playing 16:9 programming or running one of the TV's tools that prevent/get rid of IR. The issue you're probably looking at is burn-in which is a dead issue now. The only way you could burn-in a plasma with newer models is if you were really trying but there have been tests that show it would take a long time.
This article is from 2008 and had the testers leave a video game menu screen on for several days. While there was IR there was no permanent damage and the IR was removed easily.
http://www.electronichouse.com/artic...ma_burn_in/D1/
Don't really know what you mean by the second question though. If you put your Mac Mini to full 1080 it'll just display your computer in 1080p resolution.
post #3 of 11
well, i guess i am concern is about burn-in as i may have the desktop of my mac mini onscreen. really, i turn it off, but my wife/son may not.
i dont know why i am so frightened of buying a plasma. price is right, size is right, picture quality is all there... yet still.. i have this knot in my stomach... WHY???
help? i want to purchase this set tomorrow.
post #4 of 11
also, what about life of the TV? am i looking at a brightness that is 50% after a few years? ideally, id like it to be a purchase that will last at least 5 years.
post #5 of 11
.. probably should look at quality LCD/LED; refer over to that forum.
post #6 of 11
any particular reason why?
post #7 of 11
Burn in is no greater a problem on plasma than it is with LCD. And Plasma will last just as long if not longer than LCD.
post #8 of 11
If you plan to connect your TV to a computer, you'd better go for a LCD TV where you will get no headache about IR.
post #9 of 11
Ha Ha.... the stuff people come up with on this forum is funny!
post #10 of 11
As much as I prefer plasmas over LCD, if burn-in is an issue LCD is your only choice. They are immune to burn-ins. The fact you actually managed to burn-in a recent model plasma means you go with a LCD.
post #11 of 11
Fanboyism at its worst. It's sad when ppl who support one thing over another will overlook facts to support their views.
