have you not noticed the string of losers slewing forth???
Removing grain where there is no grain to remove and replacing with artifical grain?
overdone enhacments....and so on on and on...
Patton, Elizabeth, Out of Africa, Sparticus, and feel free to add to the list as there are many I have overlooked
http://www.hometheaterforum.com/foru...cus-in-blu-ray
that should fix
where before, we had heavy noise as captured by the hd transfer, we now have something akin to the surface of a quiet pond in which not even the smallest ripple distorts the surface. Make no mistake, the video noise inherent in the hd master was a problem. the film element upon which the master was based had the normal grain attributes of large format separation masters, which are nominal. No grain reduction was necessary.
the video noise, inherent in the hd master is gone. That’s a good thing, but keep in mind that it should never have been there to begin with. In removing the noise, all grain is also gone, replaced by what appears to be a pleasant sheen of artificial film grain.
all of the detail captured by academy award winning cinematographer russell metty’s meticulous large format technirama camera, for which he won an academy award for best color cinematography, is unfortunately also gone.
that should fix
