Originally Posted by gregodorizzi
I called Panasonic a few weeks ago and was told they were developing a repair kit. They called me back this last Friday saying the kit is ready and that I could make an appointment for the repair. You should call them. For what it's worth, the buzzing on my unit was really loud when I first got it in June but greatly diminished after a few months.
Well, I follow your advice and I did call Panasonic Canada two times (to speak with two different person) and here is what they told me.
Panasonic does not consider a repair on a plasma TV except if you hear a buzzing farther than 15' or the buzzing sound is louder than the volume set at 25.
I think they set the bar pretty high. Of course when the volume is set at 25 I cannot hear the buzzing noise. But between words or during silences when the volume is set to 25, I can clearly hear it !
I did ask (following your statement) if there was a repair kit or a technical bulletin about that issue but both person on the phone told me no, this is a normal operation of a panasonic plasma tv.
It's so sad as I am really satisfied with the picture quality (SD and HD)... I need to live with it or chose another product. I've always been satisfied with panasonic products and they are well reviewed... I don't understand that they know about it but consider this a normal operation of a tv set... I mean, louder than a CRT... come on...
You're lucky to have a repair kit coming into your tv because panasonic canada does not seem to have that kit or are aware of such a repair kit...
I hope you'll be able to update your situation and maybe if you are able to provide the part number for that repair kit would be a good thing to know !
Thanks for all your advices !
