Ted, since you're here chiming in anyway, maybe I can save John another one of my emails.
If I'm planning on doing a decoupled ceiling. Is there a reasonable way to engineer what mgkdragn is talking about above and keep isolation intact?
Could I install clips to the floor between joists, double 5/8" w/ GG on hat there and then connect that "higher ceiling" to the rest of the ceiling with more double drywall? Almost creating an inverted soffit above the screen?
