AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Comcast Remote Code for Pioneer VSX-1020 (or 1018 or 1019)
post #1 of 5
I have Comcast HDTV service in the Atlanta area. I have a new Pioneer VSX-1020 receiver (2010 update of VSX-1018 or VSX-1019).
I haven't been able to find the Comcast remote code for the Pioneer receiver. Can anyone supply the code for the 1020 or 1019 or 1018?
Thank you.
post #2 of 5
Hi timboreese, which Comcast remote do you have? Try Comcast Customer Support page.
post #3 of 5
Thank you.
perfect post for the owner's thread. no reason to start a new thread and clutter the forum. i had no problem programming for my comcast scientific atlanta box.
post #4 of 5
JChin, Thanks for the reply. I have the Comcast Universal Remote - Red OK/Select Button (Motorola).
The codes listed on Comcast's site won't control the audio volume on my new Pioneer VSX-1020 (brand new product). Though I am a newbie to this forum (Winston, regrets on the clutter), I have programmed Comcast remotes many times before. I simply need the proper code for a Pioneer VSX-1020 for the Comcast Universal Remote (Red OK/Select Button).
Thanks again.
post #5 of 5
JChin and readers -
Please disregard my previous reply. I found the correct code. In fact it is 31023 as listed on the remote guide accessible from the link you posted.
Thanks again.
