Originally Posted by
rider
That's surprising that people's scores improve with successive tries ("practice")--unless they are more careful/pay more attention each time....? I mean, the colors you see are the colors you see, regardless of how many times you look at it (or is there something I'm missing...?).
I did it just once; .
No idea what your experience is with these kind of scales but since you did the test but once and scored perfect a subsequent test can show no improvement, only a repeat of your past performance or a mistake. Apparently I made fewer mistakes after the initial test by looking more carefully. I'd bet I could eventually score this thing perfect too, once I got the hang of it.
What came naturally to you may require practice in others. That is if you were new to something like this as well!
This test, being in a high end display forum, will probably tend to show higher scores then if you placed it somewhere else.
I have a feeling most here have tried to set up their own displays before with scales such as this one.
Personally, I have avoided doing this task properly, exactly because of these type of scales.
I'm sure you don't even understand this type of thinking, I can explain but it's a long story.
You see it all started one day in kindergarden....
