BEFORE:
AFTER (that was about 90%, I need to take the real "completed" photos" - have been too busy watching movies to bother):
DURING:
intro
framing
low voltage wiring
insulation
drywall
entry doors / drywall mud
exterior stucco / more drywall mud / recessed lights / GrafikEye
start of soffit framing
soffit bulkhead / false wall
THT LP #1 started
THT LP #1 finished
more soffit framing and soffit insulation
CHT 6x PRO-10, 1x SHO-10 arrive / QSC power amp fan mod
soffit recessed and rope lighting, more soffit insulation
ceiling painted / MA rack purchased
doors painted / superchunk bass traps / column framing / screen wall absorption
column face panels / carpet samples / berkline boxes
column framing finished / wall furring going up
wall panels framing mostly done
panel construction details
soffit fabric covering
soffit fabric done
column vinyl covering
column vinyl covering done / screen wall absorption fabric covering
column face fabric covering
false wall C section / door jamb fabric covering
wall panel fabric samples
carpet
berklines in / THT LP #1 in place
first attempt at sub EQ
projector purchased / testing on temporary screen
wall panel fabric going up
wall panel fabric almost done / some screen shots (still on a temp screen)
screen assembled
screen mounted (piano hinges) / screen shots
left / right / bottom screen surround panels
THT LP #2 under construction
both THT LPs installed / hinged screen supports
EQ for the two subs
XBMC talk
Unacceptable's step by step panel framing tutorial
new SEOS LCR
Edited by Brad Horstkotte - 11/9/12 at 7:32am
The attic is also required to have dormer vents, not sure if there's really anything that could keep those from leaking sound, while allowing air to flow.
Neighbors, well, we'll see...
