Now that's a nice BIG screen! Looking forward to seeing it in place. I love my XD fabric..
post #601 of 940
7/8/11 at 7:31pm
. I'll check your build thread Nick in case you documented your approach - I think I recall seeing it. Not sure you mean about the adjustment mechanism. What do you do about the top false wall panel above the screen, do you remove it when you want to lift the screen up? Since it would interfere with the hinge otherwise.
Thanks guys - started shopping for piano hinges.
. I'll check your build thread Nick in case you documented your approach - I think I recall seeing it. Not sure you mean about the adjustment mechanism. What do you do about the top false wall panel above the screen, do you remove it when you want to lift the screen up? Since it would interfere with the hinge otherwise. |
Brad for me to form an opinion I am going to need MORE screen shots........LOL
Looks awesome. The piano hinge idea is perfect and the 1/2" screws will be plenty since there is a few dozen of them. Looks great but the new screen shows me why your MW2 skills are lacking a bit |
There you go again, thread padding Brad's...thread and not getting on xbox.
Wow Brad! Stunning! Hey, my screen is on a french cleat, but the thing is so big that I have nowhere to put it when its off! I think your hinges look great, and I'm going to amend mine to be that way. Having it pinned to the ceiling when up is about the most convenient solution.
Screenshots look great too. You're going to be having some fun! |
Actually since I sold my projector we only have 1 tv available down there to play on. I am actually sitting down here watching my son play MW2 as I search AVS looking for answers to my column building issues. Where are you on that front???
Screen shots look really good Brad. I had to go back and threadsearch to remember your choice of the ever-popular screen size ratio you went with (what was it, 2.125?). Has getting it set up made you reconsider (even a little?) your current plan for no masking?
Yeah I'll have to add some more screen shots for you for sure.
I went 30-4 and 30-2 in FFA this morning ;-) - the 30-2 was basically 7 kills and then lay in the grass haha (harrier-pavelow-chopper gunner). Got accused of boosting which is always fun. Oh he was on this morning, I joined his lobby for a while until I got tired of being flashed and rapid fire shotgunned. |
