Ok, I found a steal on some Cat5(e)? cable on Craigslist... but I want to make sure it is right before completing four runs to each room in my house. He had it listed as cat5, but I suspect it is "e".
I got a 1000' box for just $5, which is why I went for it even though I wasn't 100% it is cat5e instead of just cat5. And to my surprise when I popped the box open there were 200 connectors and the crimping tool for attaching them.... so the deal was even sweeter than I thought. On the box it is labeled as cat5, but it also has a sticker on the box that says "certified cat5 or cat5e, up to 350mhz".
Is there any way I can tell by any markings on the cable that it is, indeed cat5e?
Thanks in advance for any input!
