Correct
using any outboard amp will make noise although you wont have any filter or eq or LIMITING!!! This is the main reason Mark and I are working on a drop in amp, that way it will be DROP IN, not a diy. yes you can get 2 of the 3 various ways ( and you need to know how to do it) but you cant get limiting other than using restraint on the gain/volume controler
