I did the cap fix on my V2 a while back and it worked well but now I am also getting the crackling noise. It is heat-related and sounds like a bad transistor. When I get a chance to troubleshoot I will post the results.
The best bet for most people with bad amps at this point would probably be to get an outboard amp and be done with it. At least until a turbo option is available. I happen to have some extra pro amps lying around, so I will probably just go that route as well.
I don't know anything about capacitors or small electronic parts like it. I was about to order them from Partsexpress but now I am not sure if I should. I went on Digikey.com but I am overwhelmed by the amount of choices.
