Originally Posted by Mr.Metal
I haven't been on this forum for a while, but today, my MFW-15 amp started humming like crazy. Now, it always had a little hum that wasn't audible as soon as the audio came on, but now it's bad. Very bad. Sounds like the common issue.
I bought my sub in August 2008, so I'm not sure what amp version I have. I'm not really good with small electronics, so replacing capacitors seems like a bit of a problem. Reading around, I see that replacement amps were offered, but are no longer in productions.
So... what are my options for fixing or replacing my humming amp now?
Thank you in advance.
Mr. Metal
Check out the link in my sig. Your sub should be a V2 and the hum fix should take care of your problem.
I'm here to help so don't hesitate to contact me.
Murrel
Leave it on and just don"t worry about it
