Originally Posted by
DC2R714
Thanks man. Ya if you find out what filter it is I can probably register it and use filter tweaker.
I come bearing news, wierd X-Files type news, lol.
I installed Quicktime alternative + Klite basic. Downloaded a movie trailer (for Step Up 3D) of Apple Trailers using the MOV download tool that pops up when you have Quicktime alternative installed. When asked, i said to rename it to HDMOV.
Trailer downloaded fine, played fine in WMP12. Opened up GraphEdit and i saw that the splitter used was the MPC MP4 splitter.
Now the wierd part :
Then i uninstalled Klite, cleaned up my sistem with CCleaner, rebooted. upon reboot, i tried to play the video again....and it worked. Tried a graphEdit, no dice, the app can`t load the graph, so i presume it`s now using an internal MS splitter or smth.
What are you using to download those trailers from Apple Trailers ? Try Quicktime alternative with the option to rename the files to HDMOV, the way i did, and see if it works (ofc, don`t install Klite or anything) and report back.
